8 foot disk additional weight ?
Pointer Hollow Farm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pointer Hollow Farm Quote  Post ReplyReply Direct Link To This Post Topic: 8 foot disk additional weight ?
    Posted: 22 hours 9 minutes ago at 6:26pm
On this disk someone has welded two bolts on the frame (a set on each half), I assume to add weight to the disk.  I was thinking about adding some weight and I have some wheel weights.  The weights I have weigh about 140#'s each.  Would it be too much to add the extra 140#'s to each side or would that be too much for the bearings, etc.
I was debatiing on doing that or adding one 140# weight in the center of the disk.
Thoughts?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 19 hours 34 minutes ago at 9:01pm
Common addition of weight locally is a rail road tie cut to length. Haven’t seen them cause any issues.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 10 hours 8 minutes ago at 6:27am
Probably the bigger problem you'll run into is keeping the front-end on the ground.  Too much weight and picking the disc up could be a problem too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pointer Hollow Farm Quote  Post ReplyReply Direct Link To This Post Posted: 9 hours 20 minutes ago at 7:15am
I just added 300 pounds in weight to the front.
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 9 hours 1 minutes ago at 7:34am
If its not cutting enough a pull type (drawbar hitch) disc is the way to go,they will cut better and you can add all the wieght you can pull no problem.
This page was generated in 0.039 seconds.
