7GB track loader
Larry O F View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry O F Quote  Post ReplyReply Direct Link To This Post Topic: 7GB track loader
    Posted: 19 Jul 2021 at 4:02pm
I am in need of parts for my 7gb track loader.  The outside bearing for final drive shaft number A23196-0 or Fiat allis number 70629354. Also need the Nut number 70081242 and nut sprocket retaining number 70621241.  Can anyone help?
Thank you.
Lazyts View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lazyts Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2021 at 7:33pm
The bearing comes up at Minnpar.com.  Shows no stock- not sure if it is still available.  Might want to check the dismantled listings on Machinery Trader...?
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2021 at 7:45pm
I check tomorrow if am still have these parts and comback to you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry O F Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2021 at 9:01pm
Thank you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2021 at 11:40am
I have 1 used double bearing with 2 cup and have the big nut and have new seal rings and boot spring assambly  for HD7.
                         gemdozer@hotmail.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry O F Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2021 at 2:36pm
I have sent you an email.  I am interested in the parts.
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2021 at 3:41pm
7 and 7gb are different machines.  make sure you are on the same page here.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry O F Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2021 at 3:51pm
I believe the 7hd and 7gb use the same final output shaft components.  If that is not correct let me know.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2021 at 5:26pm
The 7g and 7gb use the same  outpout shaft and  components only the ring sprocket is different.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry O F Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2021 at 5:57pm
What about the 7HD? Is it the same.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2021 at 7:13am
HD7 with 3-71 gm is old monolithic powertrain.  single reduction finals.  built same time frame as HD10 and HD14
HD7G is 20 years newer uses double reduction finals and 7GB is an update basically the same.
Which machine do you have?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry O F Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2021 at 10:33am
I have a 7gb track loader 1972.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2021 at 11:43am
ok.  no worries then.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry O F Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2021 at 5:57pm
Thanks to Hector my 7GB digs again.
