7g=b loses ttans pressure
edwin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote edwin Quote  Post ReplyReply Direct Link To This Post Topic: 7g=b loses ttans pressure
    Posted: 18 May 2013 at 10:39pm
just bought machine. sometimes has trans pressure for 30 seconds . other times no pressure at all.all suggestions welcomed. Wher might ther be screens or filters ..thanks for your time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2013 at 6:07am
7G B has a similar trans screen to the 7G, in the main trans case where the steering and main trans pump suction lines attach is a flange bolted to the face of the trans, drain the trans, remove the flange, on the backside attached to the flange is a permanent screen filter. As to the remaining filters I am not up on the B series, there should be filters for the steering and the trans in housings in-line to those systems. On my 7G the steering filters were behind a panel aside the shifter while the trans filter was hanging between the trans and the torque converter.
This page was generated in 1.418 seconds.
