7g recovered after 10 years |
Tjsauto
Topic: 7g recovered after 10 yearsPosted: 20 Sep 2020 at 11:30pm |
Got a 7g out of the woods after sitting there for 10 years or more the man that owned it was clearing 0ut some land but there was no belly pan on it ripped out some hoses then let it sit at the time it was sitting on the ground but years later was washed out under neath finally got it home the injector pump plunger is broken I've been looking at this site and no there are little or no pumps out there I seen someone talk about a pump head that had serial number # 5900ar that is what mine has new to this site will show some pictures
5 ![]() ![]() ![]() ![]() ![]() ![]() Edited by Tjsauto - 29 Sep 2020 at 7:14pm |
Ian Beale
Joined: 03 Oct 2011 Location: New South Wales Points: 1009 |
Posted: 21 Sep 2020 at 1:09am |
I've got a .pdf listing of heads. This shows 5900 as a replacement for at least one earlier one (I haven't looked hard) but not having any successors. The "R" means the head has been rebuilt
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35642 |
Posted: 21 Sep 2020 at 6:23am |
AMBAC pumps are no longer parts available by Am Bosch, the availability of repair parts has gotten so limited few will even look at them around here. About the only way to procure the internals is find another pump on a engine or on a shelf that has not been rolled to break the plunger and disassemble that pump, CAREFULLY.
Ian Beale
Posted: 22 Sep 2020 at 4:46am |
Been a while since I went through this on an AC Forty Five. Likely there is a stud that goes into the head on the rear (towards the back of the machine). It is an oil feed and you have to take it out to remove the head - including the square rubber ring on its tip - which will hold the head if you don't. And you take it out carefully as it is one of the "unobtanium". I've seen a suggestion that an o-ring can be used but no details - IIRC it would have to be a fat one.
Tjsauto
Posted: 28 Sep 2020 at 7:34pm |
I'm still trying to figure out this camera to post some pictures
gemdozer
Thanks(1)
Posted: 29 Sep 2020 at 5:31am |
I check today if am still have a pump plunger because have 2 injections pumps dismantled for parts
Tjsauto
Posted: 29 Sep 2020 at 7:11pm |
Thanks let me know it broke the spring and drive plate also I read some where the drive plate is still available but I don't know where
gemdozer
Posted: 30 Sep 2020 at 8:13am |
I check yesterday and have a plunger 3 1/2 inch long and a spring 1 1/4 inch long and if you could send a picture for the pieces to make sure.
gemdozer@hotmail.com
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8979 |
Posted: 03 Oct 2020 at 2:18pm |
What's the chance another pump could be adapted. Seen Cummins semi puller with a Cat injection tied on it. Anything is possible.
gemdozer
Thanks(1)
Posted: 03 Oct 2020 at 3:37pm |
I found a complete pump PSB4A-100EH 5007A1 and parts number 4336644 and this pump should fit on 344 motor hd6
Ian Beale
Posted: 03 Oct 2020 at 4:59pm |
What's the chance another pump could be adapted." IIRC - Big problem is that PSB pumps run at crank speed and the reduction is in the pump
Tjsauto
Posted: 25 Apr 2023 at 9:41pm |
do you still have pump
gemdozer
Posted: 26 Apr 2023 at 1:06pm |
Yes am still have the injection pump -PSB4A-100EH5007A1
