7G and 7G-B
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Topic: 7G and 7G-B
    Posted: 16 May 2015 at 9:11pm
As most here already know, I am the somewhat proud, or not, owner of a 7G, one of the last built and supposedly with FA markings when new. It has the typical for the time hand clutch controls and steering brakes but if you do not use the clutches just brakes. All is mechanical/hydraulic.
To make a long story longer and more boring I had chance to look at the steering mechanism on a 7G-B, of course it is predominantly a Fiat product but used the same final and trans as my older unit just has full foot control of the steering. The second tractor I bought for parts had been cobbled together to do similar but they failed to add the third brake pedal to stop the unit without applying clutches. I feel I am about to embark on a conversion to the later style brake control and free my hands on the remaining controls, the decelerator will need to move but can go where I choose, just have to set down and figure out the over-running linkage assortment to make three pedals work as units in common. I am also going to try to improve the single bucket control built two seasons ago.
Have looked to the old illustrated parts guides with those as template.
Edited by DMiller - 16 May 2015 at 9:13pm
HD6 Merv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6 Merv Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2015 at 2:24am
afaik Dave the series B was a AC product; most parts are still the same as 7G; except for the 3500 engine. The controls for steering and bucket are an 'evolution' over the machines design period.
tits tyres and tracks
they all cost you money
Mactractor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mactractor Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2015 at 3:38am
The AC engineered machines in production when Fiat took over all got the Fiat Allis decals without any Fiat engineering in them.
When Fiat did apply their engineering to the line, the loyal AC buyers began to drift away to Komatsu and others rather than tolerate the pathetic product from Fiat
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2015 at 5:25pm
I really like the single stick bucket control I built but needs 'honing', the style of linkage on the B seems simple enough to duplicate.
I did see the earlier version 7G-B, did have a similarity to my own machine but had the 3500, were these any easier to work on than the Lanova 7000? Did they do any better repair wise?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mactractor Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2015 at 7:23pm
The Lanovers were the Buda`s before the AC thousand series engines, and had injectors in the side. The 6,7,10, and 11000 engines gave very good service for their owners, and it would be a tall statement to say 3500`s were a better engine in any respect.
Lazyts View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lazyts Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2015 at 12:03pm
As Mac stated, the 7G-B was all Allis Chalmers.  I've got a picture somewhere of a dealer meeting in the spring of 1974, just after the merger, in which both the 21C and 31 tractors appear.  This tells me that Fiat developed NOTHING in the tractor line after 1974, except adding european product.  The only thing I can see that they might have developed was the twin engine 262 scraper....
It's really too bad, they might have been a contender.Ouch
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lazyts Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2015 at 12:08pm
As also stated, the small AC engines gave good service, but the 844 really let them down in the big stuff- scared people away from the 945 loaders, 21 tractors and the big scrapers- from what I've heard, they rarely made it past 5000 hours.  A Cummins engine might have been a good fit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lazyts Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2015 at 12:32pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lazyts Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2015 at 12:46pm
Tractor line: (from left) 41B, 41, 31, 21C, 21B, two 16Bs, 14, 11B, 10 and 8
Wheel loaders: 945, 745HB, 745B, 645B, 605B, 545B, 345
Not sure of crawler loader models, but looks like 7GB and 12GB are both there
Graders: 65, 100C, 150C, 200C
Motor Scrapers: 260B, 261B, 460C
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mactractor Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2015 at 5:09pm
Good old brochure Trev. I agree Cummins 855 was the solution to the 25000 engine troubles. Some of my Australian neighbours repowered their 460 and 562 scrapers with 8V92T`s which made them happy modules (when diesel fuel was dirt cheap)
mudlord View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mudlord Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2017 at 5:55pm
I have just purchased a Allisfiat 12GB track loader , i had a heavy equipment mechanic change all fluids and filters. It cranks and runs great , but he said the steering clutches are worn out , it will drive fine but will barely turn one direction . I am trying to find and order a clutch kit for this unit but i am having a hard time finding what i need can some one on here give me a little advice please !!!
Ian Beale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2017 at 10:03pm
Do the brakes work?  If if is like a FA 10 they run off the same circuit as the clutches and when working properly you should be able to feel the pedal pulsate when applied hard.  There is a filter under the driver's left foot on the front of the bevel case.
If the oil level in the bevel gear case (from where it pulls oil for those circuits) gets very low you can get some interesting effects of not wanting to steer.
Today - I was assuming it was a Fiat type 12.  If it is an Allis type ignore this
Edited by Ian Beale - 02 Nov 2017 at 5:22am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lazyts Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2017 at 9:21pm
Would check brakes first, and adjustment of linkages, as both the steering clutch and brake are on the pedal, correct?  Will each track stop independently when under load?   Worn out clutches would make it want to steer one way or other all the time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2017 at 4:36am
Clutches worn cannot do this, bad seals on clutch disengagement mechanisms can. With my 7G the system uses a secondary hydraulic pump, engine driven to release the clutches, if weak will release them poorly, if damaged will not release at all, if seals are bad at clutches actuators will cause as you indicate. I have rebuilt both my actuators this does require clutch removal and replaced my steering/brakes pump.
Edited by DMiller - 02 Nov 2017 at 5:31am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2017 at 5:41am
If anyone has parts for this is Minnpar, Minneapolis. If they do not have the next step would be to disassemble and take the components to a hydraulics shop for seal matchup, will be Teflon or another type hard quad ring seals. There are hydraulic hoses inside the clutch cases on these, from the actuators to a thru fitting then to the controls assembly, these could be bad.
Edited by DMiller - 02 Nov 2017 at 5:42am
This page was generated in 0.695 seconds.
