780 forage harvestor
Message Reverse Sort Order
Noel Brown View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Noel Brown Quote  Post ReplyReply Direct Link To This Post Topic: 780 forage harvestor
    Posted: 13 Nov 2020 at 3:54pm
Hello I have 2 hay pickups for 780 in pretty good condition if your interested give me a call 606 383 3108
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2019 at 9:37pm
The 780 was cut and throw. It chopped well if you kept the knives sharp and had a good shear bar and kept it set properly. They threw corn much better than grass but worked ok if you had good windrows and it was quite high in moisture.
The two row corn head I had was wide (34" to 36" rows). I'm nit sure if they were all the same.
A few years ago, when the farm was sold, I sent a working 780 with a one row corn, two row corn, direct cut and pickup head for scrap. I tried to give it away to anyone that would use it, but I had no takers. I gave my working 443 baler with thrower to a guy and found out later that he sold some parts off it and scrapped it.
ebowman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ebowman Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2019 at 11:54am
How well did the chopper chop the corn? Did it shred it or chop it? Will that corn head work on 30" rows or is it for wide rows?
WD45, '62 D17 Diesel, '65 190XTD, '74 7030, 1958 Roto-Baler
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2019 at 9:04am
That's cool Joe
Joe Graunke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe Graunke Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2019 at 8:10am
Here’s mine. The corn head on back in brand new!!
Joe
Edited by Joe Graunke - 15 Mar 2019 at 8:10am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2019 at 10:53am
What other ac stuff do you have, were about ten min from Albany
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2019 at 12:27pm
Ok cool
Doyle B(NY) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Doyle B(NY) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2019 at 12:23pm
I'm in central NY about an hour from Albany
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2019 at 9:56pm
To bad the early chopper grass head wasn't similar, have lots of parts for it.
Where abouts in ny are you
Leadoff View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leadoff Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2019 at 9:43pm
I have not seen many Direct Cut Headers for the 780/782 on this site or sales ads.  The Pickup seemed to be the preferred for silage. It is rare to see a Direct Cut for used New Holland, Gehl, JD, etc as well
Ford sold a 680 Forage Harvester that is identical to the AC 780/782 - not sure about the Header options available, but might help in your search - keep an eye for a blue one
Marketbook has an AC 782 with a two row corn Header and the description notes a "Bean Head" is also available - might be worth a call
Our local AC Dealer had this Direct Cut Header out in his bone yard.  It is very well built, and didn't take too long to get everything running.  The auger fingers were seized, but lots of WD-40 and TLC got them working.  The reels wood pieces are quite weathered.
Good luck with your search, and I will keep an eye out as well
1963 D17D Series III. 1965 D15 Series II. 1965 D17 Series IV. 1975 185. 1978 716H. 1979 716H. 1965 780 Harvester/1R&DC. 1957 Model 73 SC 4 Furrow Plow
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomstractorsandtoys Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2019 at 2:40pm
Hay pickup heads can be found but a direct cut is rare. My Grandfather bought a new 780 with 2 row and a direct cut head. I to would like to find one for my 780. Last fall we planted oats in Aug for a cover crop and after a couple hard freezes we used a direct cut head to chop 10 acres and put in a silage bag. If you do find two let me know as I would travel to get a usable one. Tom
Post Options Post Options   Thanks (0) Thanks(0)   Quote Doyle B(NY) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2019 at 8:38am
I bought a 780 chopper with a two row corn head a few years ago. Its in excellent shape. However I was wondering if I could find a hay pick up or direct cut head for it. Are there many out there?
