78 air planter
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Topic: 78 air planter
    Posted: 03 Feb 2010 at 4:21pm
Is there a cheaper source for the foam cut off seed pads other than the $44 each at AGCO? Looks like $90 per row! Looking at a 333 air planter this weekend. Thanks. Lonn
Wink
I am a Russian Bot
michaelwis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote michaelwis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2010 at 8:15pm
lonn . did u get that planter ? was it a 6 row ?
WD WD45 DIESEL D 14 D-15 SERIES 2 190XT TERRA TIGER ac allcrop 60   GLEANER F 6060 7040.and attachments for all Proud to be an active farmer
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2010 at 5:23am
No money exchange yet but going to look at it maybe Saturday if weather permits. Yes it's a 6 row 30 in. Never owned an Allis planter before. Have a Deere 7000 4RW right now and it has seen it's better days and since I picked up an M2 with 6x30 corn head I need to make a switch and with only 83 tillable acres I thought the high priced Deere and White planters were too much. Do you know much about 78 air planters Michael?
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote michaelwis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2010 at 6:07am
back in the early 80,s we demo,d an  ac air no till planter ..  it usesd  seed disks ....it put the seed in the ground exeptional .. but dad  got a better deal on a  ih cyclo . go figure  .. piece of junk .. which got traded for a 7200  jd  really liked that planter . should have kept it ..
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2010 at 6:09am
I see you're looking for a planter too.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2010 at 6:15am
Buy only the LONG seed pads.....short ones are not needed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote michaelwis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2010 at 6:17am
LONN ,,YES I AM .. good ones r hard to find
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2010 at 7:44am
Thanks DrAllis, apparently no aftermarket?
Michael, I can't find many in upper midwest but there seem to be a lot more straight to the south. Quite a ways away though.
Wink
I am a Russian Bot
Wade (IA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wade (IA) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2010 at 8:01am
Michael, are you looking for a wide or narrow row planter?
Kevin(Alabama) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin(Alabama) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2010 at 8:24am
I ran a 12 row 30 with 78 air units. It was a good planter but for no-till the coulter springs are rubber and had trouble with them braking. If you could find a Deutz Allis 385 you would have a much better planter for the same money. But you still have the same coulter springs but could easily replace them with a yetter or other coulter. But in your area the coulters would not take the abuse that they take here either, but this problem is with no-till only.
"I would die a thousand deaths before I would betray a friend."...Sam Davis, Nov. 27, 1863.....DEO VINDICE
Post Options Post Options   Thanks (0) Thanks(0)   Quote michaelwis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2010 at 4:34pm
QUOTE=Wade (IA)]Michael, are you looking for a wide or narrow row planter?[/QUOTE]
6 row narrow
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2010 at 8:32pm
kevin, alabama,  Did the Deutz 385 ever come in a 12 row, 36 inch configuration? If they did, where could I find one?  Darrel in ND
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin(Alabama) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2010 at 2:09am
I'm not sure darrel, I will look in my manuel and see. I would think you could make a 10 row 36 out of a 12 row 30. I will get back with you.
