7580 |
SHAMELESS ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: EAST NE Points: 29486 |
![]() ![]() ![]() ![]() ![]() Posted: 27 Nov 2011 at 2:00am |
looking at a 7580, this one has the power shift...did all of them have it, or did some have the PD? i think i would rather have the PD in a big tractor, i like the power shifts on smaller tractors! how did the power shifts hold up in the big tractors?
I did not know any 7580 had the power shift. 7080 did not have PS, only went up to 7060.
I would say it would hold up in a 7580. Power through the PS never seamed to be a problem. MACK
Chris/CT ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Niantic, Ct Points: 1939 |
1981 dealer price sheet shows PD only [ no option for PS] in 7580.
Price was $59,469.00. Wonder what that price would be in today's dollar? Also equipted with fully independent PTO/1000, what implement would you pull and need PTO on that beast? Edited by Chris/CT - 27 Nov 2011 at 7:20am |
Orange Blood ![]() Orange Level ![]() ![]() Joined: 29 Nov 2010 Location: ColoradoSprings Points: 4053 |
Chris, if you pulled a planter, pull type or if you really wanted to a 3 point, then a lot will need the pto for pump work.
Shameless, how do you know it's power shift, I am guessing you are looking at an ad. People call the two speed power dirrector on the floor a power shift some times.
Still in use:
stray ![]() Orange Level ![]() ![]() Joined: 16 Aug 2011 Location: Tipton, Missour Points: 323 |
I was looking at Schulte mower's web site (we have there 15' batwings at work) a few years back and they offer a 42' batwing rotary mower and the picture shows it being pulled by a compareable large JD 4wd tractor.
1969 190XT series 3
Dans 7080 ![]() Orange Level ![]() Joined: 05 Feb 2010 Points: 1146 |
Grain cart, Manure spreader....
darrel in ND ![]() Orange Level ![]() ![]() Joined: 22 Nov 2009 Location: Hebron, ND Points: 8679 |
if you found a 7580 with a powershift, someone had to of put it in there themselves. Suddenly planted an idea in my head, though. I've got this 7580 with the tranny out, and this burned up 8050 power shift that the tranny should still be good in............Naw, I don't think it'll work! LOL Darrel
The power shift was never offerd in the 7080 or 7580, due to the high horsepower. That is the reason the 70"80" became the 80"70", The tractor was detuned as to not over power the powershift.
orange...it had the power shift stickers on the door! just like on the 7060's!
oh...and the shift console looked a whole lot different than the PD console! door was locked so couldn't get in!
i worked for AC for awhile back in the '80's, but never was able to get close to a 4x4 to see or drive. no one in our area wanted a 4x4 of any color back then!
dpower ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Madison Ne Points: 1576 |
Why don't you go to Johnson's in Fremont they had a 7580 redone with a Duetz motor sitting in the back. It actullay looks like it belongs in the tractor
The shifter was different on a 7580 than the other tractors. MACK
427435 ![]() Orange Level ![]() Joined: 18 Nov 2010 Location: SE Minnesota Points: 18637 |
Actually, the main reason was to gain engine reliability. The 426 wasn't all that happy about turning 2550 rpm. |
Mark
B10 Allis, 917 Allis, 7116 Simplicity, 7790 Simplicity Diesel, GTH-L Simplicity Ignorance is curable-----stupidity is not. |
Mack, I am not accustomed to you being wrong, so please explain what you mean by different. I looked on the AGCO online parts book, and the T-handle shifter is the same as any other 7000 series of similar size, excluding the small models like the 7000 The floor stick is also the same, in the early models.
Shameless, did you see a big T-Handle on the right console, with kinda a hump down where it goes into the console? That was the redesigned T-Handle, which did nothing more than move the "stick" off of the floor, but it is very much a standard power dirrector transmission.
Still in use:
injpumpEd ![]() Orange Level Access ![]() ![]() Joined: 13 Sep 2009 Location: Walnut IL Points: 5033 |
the powershift was not offered in the 7080/7580 because of the higher rpm, not because it wouldn't take the power.
The range-park shifter was made heaver because the range trans was in the back bogy. So had to have bigger cable to go that far. MACK
o-k...thanks! if i go look again, hopefully i can get in a drive it! or at least be able to look over it better in the cab! i did see the "T" handle with 3 slots on the console! i figger'd it was high/low and the the power shift slot.
Adam Stratton ![]() Orange Level Access ![]() Joined: 11 Sep 2009 Location: SW MO Points: 1363 |
On our 7580, the park brake engages a metal plate with slots in it instead of just moving a cable like the 7045 and 7060 I have. It is more heavy-duty, and doesnt bind as often as the others do, but when you accidentally get it between high/low/park, it is a real mess to move things around with your plier handle to get it all going again. The PTO is the big 1000 rpm shaft on ours.
Mike Kroupa ![]() Orange Level ![]() Joined: 02 Oct 2009 Location: pierce, ne Points: 335 |
Hi-Lo range is in the drop box, bottom output shaft if I recall, powers the frnt. axle as well as rear axle. hth, Mike
