7580
ajl View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ajl Quote  Post ReplyReply Direct Link To This Post Topic: 7580
    Posted: 03 Jul 2019 at 3:38pm
Going to check out a black belly 7580.  Has 5500 hrs and is a 79 model.   Cab interior looks good so seems to confirm the low hours.   What should a guy look for on this tractor?   Planning to keep the implements small so will not use max power often for engine longevity as I know the 426 is maxed out.   Have run a friend's 8070 when the clock ticked over 13000 hrs so have seen these engines last.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2019 at 3:53pm
U-joints on both rear driveshafts. The top one is the worst as it runs engine speed.
Edited by DrAllis - 03 Jul 2019 at 3:53pm
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2019 at 10:06pm
I got one with a Cummins repower for sale.
Austin IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Austin IL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2019 at 10:30am
Other than being cheap, I wouldn't want one. Terrible cab and way underpowered
Fogarty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fogarty Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2019 at 10:50am
Under powered for what ?
It was never meant to pull like a freight train.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Austin IL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2019 at 11:52am
Well they surely weren't built to pull a 6 row planter. Way too much rubber on the ground for a 426
bigal121892 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigal121892 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2019 at 2:25pm
Back in the day, we had 7080's, and a 7580. 7580 pulled the same implements as the 7080's, and did the heavy tillage. Our reasoning was on a Blu-Jet, the power was split between two differentials. Had less wear and tear on the finals that way. The 7580 also works great on a hay mover in the winter.
Edited by bigal121892 - 04 Jul 2019 at 2:35pm
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2019 at 11:40pm
I find you have to keep the revs up to get the power needed on a 7580.  The drive shafts are the weak points of them but if kept well greased and inspected, seem to hold up well.  It is a pain to grease some of the zerks though...
Allis Express participant
GM Guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2019 at 1:05pm
Did you buy it?
Driveline condition is a biggie, lots of $ can be dumped there if not in good shape.
Dr. Allis, any suggestions on a source for new u-joints? my #2 joint on the bottom shaft is out, and I am not paying the price Agco wants. I will likely source used in case I cant find a deal on a new one.
As far as other things, check for leaks and fluid condition, and run it through all the gears, make sure the Power Director shifts smoothly, check PTO and 3pt operation, as well as remote lever travel, as there is long expensive cables in there that would be nice if you dont have to replace. :)
Good luck!
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2019 at 3:23pm
Here is a Allis pic straight from the 1976 Annual Report just introduced at 185 horses
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2019 at 3:26pm
T in ne View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote T in ne Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2019 at 6:48pm
I had a 7580 for a couple years, bought it off the neighbor around 2003 with 3200 hours, he bought it and never ran it in 10 years, he's claustrophobic. Twice the drawbar tractor of the 3788, half the pto tractor. A flatter steering wheel would have made entry easier. But seemed to be plenty of power.
A 3 foot hose on the grease gun made greasing the universals a lot easier.
