7580 won't move
crow View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote crow Quote  Post ReplyReply Direct Link To This Post Topic: 7580 won't move
    Posted: 16 Apr 2023 at 11:01am
i bought an Allis Chalmers 7580 last year and when using it to cultivate , it stopped moving. The PTO , hydraulics and steering all work but it won't move in either forward or in reverse. Any ideas as to why? thanks
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2023 at 1:07pm
BTDT
Seems like it was a shaft on the bottom of the transmission snapped. Cab needed to be tilted way back to do it.
MikeKroupa View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote MikeKroupa Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2023 at 7:15pm
Check the transmission/dropbox coupler. Remove the plate underneath the battery box and take a look. Good Luck, Mike
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2023 at 8:12pm
Took the splines out of PD hub.               MACK
crow View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote crow Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2023 at 8:37am
Thanks for the ideas as to what is wrong. When I get it in the shop we will have a look.
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2023 at 9:11am
second trans output shaft coupler.  done one
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2023 at 11:00am
If the splines are gone in the power director hub like Mack says,then you should be able to put it into gear without any gear grinding. This is with the engine running and the clutch pedal up.
crow View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote crow Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2023 at 8:45pm
No it is still grinding when i put it in gear.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2023 at 9:04pm
Then, I would think that if you put it 5th gear, release the clutch, throttle up a bit and step on the hi button, you should "hear" things whirring under the cab floor. This is with the range trans in low range. That to me would mean the coupler after the transmission, not the clutch housing splines.
Adam Stratton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam Stratton Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2023 at 10:59pm
No chance the range lever popped out of gear? Does it act the same way in both ranges? Had a cable break on the range selector on an older steiger the other day and acted a lot like you are describing
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2023 at 3:20am
the floor buttons not stuck halfway? sometimes dirt gets down around them
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2023 at 7:14am
Along Shameless’s lines I had to run my 7580 in high for a few years. Big heavy zip tie saved the day.
This page was generated in 0.130 seconds.
