7580 Steering
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Topic: 7580 Steering
    Posted: 24 Apr 2024 at 7:14pm
My new to me 7580, when I am turning around with the disc it always steers fine the direction I turn it first but when I steer back to straight the steering wheel turns hard and the steering comes intermittent, with when the wheel gets hard to turn.  If i go slower turning the steering wheel then it doesn't do this, it makes no difference how fast ground speed is, how hard it is pulling, nor if the throttle is wide open or anywhere down to 1000rpm.  Wondering if there is a priority valve in the system....new filter and new fluid with about 50 hours on them.
What the heck is going on here, does the same when cold as when hot
SilverShoes View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SilverShoes Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2024 at 1:57pm
Quite possibly one of the steering cylinders is leaking
Tim NH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim NH Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2024 at 7:39pm
Amos, did you figure the problem out.   Tim
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2024 at 8:20pm
Tim, have not had a chance to work on it yet, truck transmissions skid steer engine removal, replace relief valve install skid steer engine 4w305 injection pump and injectors and shipping out 15K bushels of corn have been getting in the way of even looking through the service manual,,,,and all the everyday things around this friggin' place....
