7580 cab swap?
Peterson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Topic: 7580 cab swap?
    Posted: 19 May 2016 at 11:44am
Ok guys as I sit in the 7580 disking, I can't help but ponder what it would take to graft a 4w cab onto this thing. Are the main frames the same width? Cables and hoods should be easy. Would the electric solenoid high/low valve fit on the original 7580 valve? Or just put the push buttons in the floor? Think it would be cool, and be much more operator friendly!
7095-685I at 255hp, 8070-225HP,8050-210Hp,8030 with 155HP,220 with 670T engine with A-pump, 7580, 185 with 140HP, 2-6080's,6070, S4 D17,wd45,CA,st34 agco, S1 D17 with 3500MK2
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2016 at 11:46am
7060 prototype
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2016 at 11:56am
The 8000 cabs are much wider, so I doubt the mountings are the same.  I don't think the 8000s had the buttons on the floor either.  It's a nice dream, but I think it would take a lot more to get everything to work properly.
Kevin in WA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin in WA Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2016 at 12:17pm
PD valve on 4w220 and 8000's is different, and mounts on the side of the transmission instead of the top to make room for the cab.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2016 at 12:22pm
Are the transmission castings the same. Could one swap the 4w/8000 series valve onto the 7580's? Or to make it simpler, just swap a powershift into it! Lol
ILGLEANER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ILGLEANER Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2016 at 3:41pm
the hardest part would be finding an 8000 donor cab cheap enough. They only made 175 220s
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2016 at 4:42pm
4w305 should be the same cab.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ILGLEANER Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2016 at 8:49pm
Yes they are.
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2016 at 10:43pm
my son and I may take a shot at putting a power shift into a 7580 this summer. If we do, I'll be posting about it on here. Darrel
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2016 at 11:16pm
ahhhhhh....someone else...that don't gots nuff to do! lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2016 at 7:02am
I was going to invite you up to help us SHAMELESS, cause I know you don't have enough to do. But if you helped us out, it probably wouldn't have brakes that worked when we got done. Lol.Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2016 at 7:27am
Installing a Power Shift into a Power Director chassis will result in a speed reduction in road gear, and all HIGH Range gear selections....about 20% slower in all.
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2016 at 1:08pm
It will go in there, though. ........? Darrel
Dmpaul89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dmpaul89 Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2016 at 2:16pm
Man that prototype looked sweet. should of just rolled with that. I never liked the 8000 series hood as much
DIESEL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DIESEL Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2016 at 2:24pm
My cousin put a 8000 series cab on a 7040 and it looked amazing you couldn't tell it wasn't factory.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2016 at 3:02pm
PICS? My idea is to take a 8070 powershift fwa and make it a 7080 open station. Man that would look awesome!!!
Now for putting a powershift into the 7580. According to the agco parts book the powerdirector trans casting is the same between7580 and 7060. So a powershift should "bolt" in. Only thing is the PTO/hydraulic straight shaft is different between the two. So if the 7060's is shorter, have a new longer coupler made to couple the drop box to the powershift. That was my idea.
joe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote joe Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2016 at 6:17am
Yes pictures of that please. Would love to see that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DIESEL Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2016 at 11:37pm
Wish I could get you some but he bought an 8070, so the 7040 didn't get used much for a couple of years and he traded it in on a new Rowse v-rake. I could of cried when I found out I would have loved to own that tractor.
