7580 bypass oil filter
powertech84 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote powertech84 Quote  Post ReplyReply Direct Link To This Post Topic: 7580 bypass oil filter
    Posted: 13 Jul 2024 at 7:17pm
I picked up a bypass filter, lines and mount off an N6 Gleaner at a junkyard this morning, but it seems the mount doesn't work on my tractor because there is a cooler line in the way. Could someone post a picture of how it's supposed to look? Hopefully I can modify this one and make it work.
Thank you!
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2024 at 9:13pm
Don't have a picture but, unless it is the bypass system with a spin on filter, I would not install a cartridge type filter. The 8000 series units were fine.
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2024 at 7:15am
You will need to do a little modification here. Make some spacers or just use a stack of flat washers to move the oil filter base bracket out. The power director line can also be bent a little to give you more room. I have also seen some that had the bracket notched with a torch to provide room for the power director line. The actual oil filter lines can be bent to fit better after you get the bracket figured out. The 8000 series doesn't use a steel line there, just a hose, so there's no interference problem.
This page was generated in 0.085 seconds.
