75 Dodge gas lineĆ· new?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Topic: 75 Dodge gas lineĆ· new?
    Posted: 22 Jun 2020 at 9:46am
What's a good replacement for a gas line on a 75 Dodge truck? From tank to fuel pump? Steel brake line, copper , rubber line? Thanks!
mhankins View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mhankins Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2020 at 10:02am
Copper would be the easiest to work with as far as flaring for fittings and such.
Steel line is good too,but would want larger diameter than brake lines.
 I would stay away from rubber.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2020 at 10:08am
True not sure what the diameter is now but thinking at least 3/8 ,
tomNE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomNE Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2020 at 10:22am
5/16 would be plenty!  1/4in if not performance.    as far as what to use.  rubber will last 10yrs and is easy to run and ez to replace.   also if you have a spot where rubber might be a problem, run copper thru that spot.  2 hose clamps and that problem is taken care of.  don't forget if fuel lines are rusted, brake lines will be next!  Now if doing a frame of restoration; then all these recommendations are for not!
AC from the start of my families farming career till the end!
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2020 at 11:18am
check out places like summit or Jeg's, or some of the resto places, I think you can get stainless steel replacement fuel line reasonable
I would not use copper.... last resort would be the copper for refrigeration, its thicker, harder to bend, and higher grade,,,
Edited by Michael V (NM) - 22 Jun 2020 at 11:21am
