720 progress pics
RLBPA1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RLBPA1 Quote  Post ReplyReply Direct Link To This Post Topic: 720 progress pics
    Posted: 05 Mar 2014 at 7:20pm
Bought it in November. Hasn't run in 10 + years. New Stator, regulator, rectifier, repaired wiring harness, rebulit carb and fuel pump, head gaskets, replacment intake manifold. new oil cooler lines. lots of claening.  Now has good spark, 100 PSI compression in both cylinders. Will soon be ready to fire up.
Seth Souerdike View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Seth Souerdike Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2014 at 8:36pm
can't wait to see her all done :D
There are no atheist in foxholes.
den/southern illinoi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote den/southern illinoi Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2014 at 4:12pm
Keep at it and it can look like this one I have.Oh, in the case of this one I'm showing, you'd also have to convert it to as narrow front end.  My other 5 are all original front end.  Den
Own 4 wheel 20, 5020 and associated equipment and 1 electric forklift. Also a 720 garden tractor, 720 Diesel. 620 and soon a 616 garden tractor.
macvette View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote macvette Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2014 at 11:30pm
Gol darnit, Dennis - always showing us some of the many you have!  Some of us feel very, very lucky to even have one!   LOL!  (and it took me about 7 years to get just one!)
coggonobrien View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2014 at 5:33pm
dennis, what did you use for the narrow front?
Post Options Post Options   Thanks (0) Thanks(0)   Quote den/southern illinoi Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2014 at 6:17pm
The narrow front was a mix of several items from around the shop.
The stem was from a "G" front end.  The axles are the "spikes" or whatever you call the rods that help pull a crop into a combine cylinder.  The rest is just metal for reinforcing, etc.  The front end is not welded to the tractor, only bolted with just 2 holes need to be drilled.  Front end could be moved to another tractor in about 2 hours would be my guess.  Really the only thing I had to buy was the rims and tires.  Den
This page was generated in 0.492 seconds.
