Unofficial Allis Homepage
720 Hydro oil
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Topic: 720 Hydro oil
    Posted: 14 Sep 2020 at 8:14pm
Been a few years since I changed my hydro oil(less than a 100 hrs ago). So I decided to change the oil and filter since this one sets outside under cover. Drained the fluid over night, picked up 6 quarts and filter. After 5 quarts I checked the level and it was way above the full mark. I started it, ran it around a little bit, let it set for 15 minutes and rechecked the level again. It is still above the mark. What am I missing here? Hood clearly says 6 quarts. No way the lines to the front and oil cooler could have more than a quart in them? Wouldn’t that have drained out?
Brad in WA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brad in WA Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2020 at 4:29am
Did you take both plugs out when you drained it? I think the temp sensor has to be removed to get all the oil out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2020 at 10:15am
I removed the the temp sensor to drain as it is the lowest point. Guess I need to pull my book out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2020 at 8:20am
Rob, I think both plugs need to be out to drain the tranny completely.  Don't remember myself now. Sheesh! A mind is a terrible thing to waste...  LOL!
Steve@B&B
Bird76Mojo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bird76Mojo Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2020 at 1:57am
I took out the sending unit today, let it drain for quite a while, then removed the suction tube and a BUNCH more fluid came out. I'd say removing both is the best route to take..
I guarantee that there's a quart in the hydro lines, cooler, pump, front circuit, rear circuit, etc..
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2020 at 7:39pm
Thanks Mojo, I do now remember doing that the last time. There is a procedure in the book describing how to bleed the system afterwards. I think I stuck a female fitting upfront and shot it in a 5 gallon bucket. It will make a mess even though it does take much to clear the air. A lot of pressure there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bird76Mojo Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2020 at 7:25pm
It should flow around 2.5 gallons per minute at 500psi.
Not enough flow to run a hydraulic chainsaw unfortunately..
