720 Hour Meter
Dave (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Topic: 720 Hour Meter
    Posted: 16 Oct 2016 at 6:10pm
While I'm on a roll with my questions on the 720, I've noticed that my hour meter is not functioning. Is there an easy fix, or do I need to replace the meter? some wiring? connections? Dave
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2016 at 8:32pm
needs 12v. when the key is on and a good ground if that doesnt work then its bad
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2016 at 9:36pm
most likely the meter is no good.  I've come across many that do not work, mine included.
mnoonan-NEWI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mnoonan-NEWI Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2016 at 10:04pm
Check out this replacement hour meter;
Edited by mnoonan-NEWI - 16 Oct 2016 at 10:07pm
AC CA, Ferguson TO-20, Ford NAA, M-M BG, AC #3 Mower, SC Plow, PH Digger, AC 720's with Ark 700 loader & Brantly Backhoe, "Mini B" w/flathead Ford V8
coggonobrien View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2016 at 7:32am
you can buy hobbs meters off ebay and amazon.  easiest way to install is pull the steering wheel, unbolt the dash and left to gain access.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2016 at 8:45am
I got the meter from surplus center and got it installed. I does work, so I'm pleased with that. Thanks for all the help. Dave
Herb(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Herb(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2016 at 12:25pm
Dave; You bought Item # 1-2507, how did you do the rectangular installation? Herb(GA)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2016 at 12:42pm
Herb, I had to take the dash loose, remove steering wheel, lifted it up so I could work under it without completely disconnecting everything (throttle cable, choke cable, etc.) and removed the old one. Slipped the new one in, put the bolts provided in, connected the wires and was done. I admit, it was kind of a pain. Hope that adequately explains what I did. Let me know if you need more info. Dave
This page was generated in 0.250 seconds.
