720 Hot indicator light. |
BrianC
Joined: 16 Jun 2011 Location: New York Points: 1619 |
Topic: 720 Hot indicator light.Posted: 22 Aug 2018 at 7:18pm |
The HOT light is supposed to go on if the hydro-stat oil gets hot.
Is it also supposed to come on during startup or cranking? How would one be made aware of a simple burned out bulb? |
IH1650
Joined: 20 Aug 2018 Location: Kennesaw, Ga Points: 3 |
Posted: 23 Aug 2018 at 7:56am |
the light should come on when cranking. If not check bulb it may be burned out.
BrianC
Posted: 23 Aug 2018 at 9:28am |
Thank you. The light bulb was bad. I can't read any numbers on the bad bulb.
Now to find a replacement. Apparently the HOT and OIL bulbs are different. Simplicity p/n is 172916, I think Allis P/N is 2028658-9. Anyone know what bulb to use from Napa or such. Edit 8/25 The p/n I gave was not the bulb, but the light assembly, marked HOT. That explains why the OIL light is a different part number. I assume the OIL light bulb is also the 1895r. Edited by BrianC - 25 Aug 2018 at 3:41pm |
IH1650
Posted: 23 Aug 2018 at 5:40pm |
the bulbs are GE 1895R
BrianC
Posted: 23 Aug 2018 at 6:59pm |
Thank you guys.
