720 fuel pump |
AC720Man
Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5488 |
Topic: 720 fuel pumpPosted: 16 Sep 2018 at 7:35pm |
Steve, I like how you resolved that issue. Sounds like a good solution.
CharleyH
Posted: 16 Sep 2018 at 1:53pm |
Where are you mounting the pump? Anyone have photos?
Steve in NJ
Joined: 12 Sep 2009 Location: Andover, NJ Points: 12071 |
Thanks(1)
Posted: 16 Sep 2018 at 8:27am |
The electric fuel pump system that I designed for those Tractors operates off a special oil pressure switch. If that engine shuts off for any reason, the fuel pump does the same so it does not continue to run! The only way that pump runs is when there is oil pressure present at the switch. Safety first! Pumps output 1-3 psi. Works fine with stock Carb. Our Electric Fuel Pump Kit for the 616-720 Tractors. Kit #1703-22. Comes with wiring, switches, relay, fuel filter, pump clamps and hose. Runs $148.95 Its on our website... Steve@B&B
rrhead(SD)
Joined: 11 Sep 2009 Location: Canton, SD Points: 441 |
Posted: 16 Sep 2018 at 7:30am |
Thank you AC720Man. I have been following those posts. I like the way SteveNJ has solved that problem. If this works out, I will try to fix that. rrhead(SD)
Edited by rrhead(SD) - 16 Sep 2018 at 3:42pm |
2 WDs,WD45,D-14,D-17,D-19D,180,7020,6080FWA,6080 2wd, 6080 2wd(cab),8050FWA,8550,4W-305,Massey 8250. Gleaner L3, R62 &R65 Agco-Allis 1616H & 1920H, AC 720, Terra-Tiger
AC720Man
Posted: 15 Sep 2018 at 10:26pm |
Fuel pump rebuild kits are available. I to would be concerned about a leak as it can cause a serious fire. Let us know how the electric pump install goes and if it solves your issue. My guess is the rebuild kit may solve your issue. Since your putting the electric on make sure the key is turned off if it shuts off for some reason or it may flood the engine resulting in an oil and filter change. Another forum member recently had this happen.
rrhead(SD)
Posted: 15 Sep 2018 at 9:35pm |
Going to be a few days. Got the new fuel pump yesterday, but we started filling silo today. Supposed to rain middle of next week, so should have time then. rrhead(SD)
IBWD MIke
Joined: 08 Apr 2012 Location: Newton Ia. Points: 4285 |
Posted: 15 Sep 2018 at 7:59am |
Keep us posted. My 720 has a similar condition I would like to solve. |
rrhead(SD)
Posted: 14 Sep 2018 at 9:29pm |
I'm having some trouble with mine. It will run perfect for about 30 minutes, then it will start coughing and acting like it is getting to much fuel. Put in new carb kit and it did the same thing. Noticed the fuel pump was leaking a little fuel and tightened it down in between taking carb off. Thought I had stopped leak but it still seeps when running. Going to try this and see what happens. Thanks. rrhead(SD)
AC720Man
Posted: 14 Sep 2018 at 8:48pm |
Just for my info, why are you switching to an electric pump? They tend to over power the needle seat and flood the engine. Not saying it’s wrong to do, just curious.
rrhead(SD)
Posted: 14 Sep 2018 at 3:41pm |
Thank you. That was my plan, but wanted to make sure it would not cause any trouble. rrhead(SD)
tadams(OH)
Joined: 17 Sep 2009 Location: Jeromesville, O Points: 11421 |
Posted: 14 Sep 2018 at 3:07pm |
I left mine on just took fuel lines off and I also left the return line on the card.
Tom
rrhead(SD)
Posted: 14 Sep 2018 at 1:15pm |
I am putting an electric fuel pump on my 720. I was wondering if I should remove old fuel pump or leave it on? Thanks for any help. rrhead(SD)
