720 Fuel Consumption
Dave (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Topic: 720 Fuel Consumption
    Posted: 16 Oct 2016 at 4:33pm
After getting my 720 last Fall, working on it a bit this Spring and Summer, I'm finally using it quite a bit, primarily to pull a lawn trailer around to haul firewood, pick up sticks and leaves in the lawn and simply just for S's & giggles. Really fun to drive around and use. However, it really seems to eat up the gas. Anyone else notice this? Is this normal? Thanks, Dave
den/southern illinoi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote den/southern illinoi Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2016 at 5:58pm
I've had one or more 720s for about 9 or 10 years now.  I've learned that you  "don't leave home without the gas can".   Yes they are hard on fuel.  Den
Own 4 wheel 20, 5020 and associated equipment and 1 electric forklift. Also a 720 garden tractor, 720 Diesel. 620 and soon a 616 garden tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2016 at 6:06pm
ok, that confirms what I'm finding out. sure do like the little devil though. has turned into a very handy addition around the acreage
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2016 at 9:21am
that onan is a gas hog
macvette View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote macvette Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2016 at 8:14pm
Yep, sure like the tractor, but sure does use a lot of gas.  It's worth it to me, tho.
talntedmrgreen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote talntedmrgreen Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2016 at 8:39am
Yup...mine may be the worst guzzler I've had, of any lawn & garden equipment.
Patterson B1*B1/B1Forklift*B10*BigTen/B1Loader*B110*B208*B206*616*Homelite T16H/T8/T7/RM7E*Landlord/Loader/Trencher*Broadmoor717*Serf525*2110*7790*Legacy XL*Twin 20*Squire9*Squire6*JCPenny 494
TREVMAN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TREVMAN Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2016 at 10:41am
This is an engine designed a long, long time ago when fuel consumption was not nearly the concern it is today. Having said that, its a good engine, good torque, good worker. Its not worth it to me to do a engine swap. If the onan pops, then I would change it. Until then, keep the gas can handy lol, Trev.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2016 at 3:54pm
I have 2 of them and like everyone else said they can be thirsty little fellows if your using wide open throttle to mow or other attachments that require that kind of rpm. But, they are just the handiest little tractor. Built extremly well with a few short comings,,,no power steering. It does a great job with my belly mower, rear tiller, front snow thrower and my Danco bush hog. Really like them both. One has turf tires and one the flotation industrial tires. Onans are expensive to repair, parts outrages, but when they run well you can't beat them for what they were in 1976 as mine are.
Chief Cockeye View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chief Cockeye Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2016 at 4:03pm
I have an AC-720 with a 20-hp ONAN CCKB engine.  It is a serious gas hog; but I also have a Simplicity 4040 with a 16-hp ONAN CCKA engine.  The CCKA is far better regarding fuel economy and there is little, if any, difference in power/perfomrance between the two tractors.
BrianC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2016 at 12:32pm
Was there ever a high efficiency flat head engine?
And yes, I am forever adding gas to my 620.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2016 at 4:35pm
There is a kit to mate a Honda engine on the 720's. Probably much better power and fuel consumption. Nothing like an Onan when they run well. Will be a last resort to replace it, I will be happy just to add more gas to the tank.
This page was generated in 0.104 seconds.
