720 Front axle's
mnoonan-NEWI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mnoonan-NEWI Quote  Post ReplyReply Direct Link To This Post Topic: 720 Front axle's
    Posted: 07 Sep 2015 at 8:34pm
Was there a heavy duty front axle and a normal duty front axle on the 720's. I have (2) 720's and one has bigger steering arms on top of the spindles?
AC CA, Ferguson TO-20, Ford NAA, M-M BG, AC #3 Mower, SC Plow, PH Digger, AC 720's with Ark 700 loader & Brantly Backhoe, "Mini B" w/flathead Ford V8
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2015 at 10:29pm
Yes, from what I've heard on here a while back, there was an upgraded front axle which was heavier. Don't know when in production they were introduced though...
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2015 at 11:24pm
think the spindle diameter is still the same size with the bigger steering arm ontop have to mesure the 720 parts tractor and the 616 had both side by side a week a go swapping hyd valves and starerter soliniod and the pto to the 720 without the carrier bearing front axles looked the same to me but i found little differances all over the two tractors that had been changed from the 616 to the 720
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2015 at 11:27pm
I don't have my parts book, but IIRR that is correct. Just a heavier steering arm and thread on the end of spindle.There was a service bulletin to add a plate for the axle pivot bolt. HTH Tracy
Edited by Tracy Martin TN - 07 Sep 2015 at 11:27pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2015 at 11:33pm
should have checked for up grades while i had my engine out on that piviot it is alll nice and tight and i did check to see  witch way the bolt was so it could be removed without lifting the engine
Post Options Post Options   Thanks (0) Thanks(0)   Quote mnoonan-NEWI Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2015 at 9:44am
Thanks fellas,
I have done the upgrade to the heavier front axle. Without pulling the engine, I had two buddies to help. It pretty much needs more than one man.
