720 finally done |
mnoonan-NEWI
Joined: 11 Sep 2009 Location: Marinette, WI Points: 739 |
Topic: 720 finally donePosted: 05 Jul 2016 at 10:52pm |
Another update on my 720 with loader. It is now done and has been to the Rochester IN & Rice Lake WI shows this summer and The Garden Tractor Daze show in Portage WI this upcoming weekend. Will also be at Hutchinson MN for the Orange Spectacular show. I hope to update the bucket to a fast-hitch system and add a fast-hitch pallet fork setup next year. By the way, the factory loader is an Ark 700 model. I will also give in detail more information on the Vega power steering unit that I installed but I want to do more testing on it first. |
AC CA, Ferguson TO-20, Ford NAA, M-M BG, AC #3 Mower, SC Plow, PH Digger, AC 720's with Ark 700 loader & Brantly Backhoe, "Mini B" w/flathead Ford V8
Mikez
Posted: 05 Jul 2016 at 10:54pm |
Nice
ACmowerguy
Joined: 20 Apr 2010 Location: Winfield, MO Points: 1210 |
Posted: 05 Jul 2016 at 10:59pm |
Wow!!! Very nice job!! Those rear tires look good on it.
Mikez
Posted: 05 Jul 2016 at 11:03pm |
We have a customer with 720, he has like tires off a sprint car on back. Was always my favorite as a kid when it was in the shop.
ac720nut
Joined: 09 Feb 2016 Location: Dexter Mi Points: 1217 |
Posted: 06 Jul 2016 at 6:44am |
Lookin good Mike. If I can ever figure out this picture thing I'll post Pics of mine
tractorman
Joined: 22 Sep 2009 Location: west central wi Points: 1046 |
Posted: 06 Jul 2016 at 8:26am |
A wonderful job, the envy of every Allis rider collector, the D21 0f the smaller world!
Wonder what it cost ?
Play on 38 B 49 WF , working on D14, D15 B10, Bee 12 B110. use 185 and 190
BrianC
Joined: 16 Jun 2011 Location: New York Points: 1619 |
Posted: 06 Jul 2016 at 12:25pm |
Yup, that is pretty. Did you load the tires? Or is this for show now, no dirt worK?
Imagine dropping gravel on the hood, yikes. I don't want to hear about you crying. Adding the power steering is something I may do some day, however I don't use a loader. If you found some pallet forks, would you want them? |
tadams(OH)
Joined: 17 Sep 2009 Location: Jeromesville, O Points: 11401 |
Posted: 06 Jul 2016 at 3:08pm |
Bucket looks to nice to use and scratch up.
mnoonan-NEWI
Posted: 06 Jul 2016 at 9:46pm |
Thanks fellas for the nice comments.
I do have beat juice (RimGuard) in the rear tires. I also have about a 500 lb. weight for the back that hangs off the 3 pt. arms. I also have a set of rear wheel weights that need sandblasting and paint. After the show season, it will become a yard work tractor which of coarse then it will get scratched and the paint will get worn off but hopefully it will still look pretty good. I will be needing a set of 36" pallet forks that will be set up for a fast hitch for next year.
7060
Joined: 16 Sep 2009 Location: Missouri Points: 1155 |
Posted: 06 Jul 2016 at 9:56pm |
And I thought I did a nice job on my 720. Yours looks like it should be in a showroom somewhere. Looks great
structures
Joined: 28 Feb 2011 Location: Beggs, OK Points: 336 |
Posted: 07 Jul 2016 at 6:14am |
Looks great.
Robert
1964 D15 Series II |
ac720nut
Posted: 07 Jul 2016 at 6:53am |
7060, I was thinking the same about my 620 till I met Mike at Rochester and he let me drive it around and try the steering, was afraid I'ld scratch it. Outstanding Gentleman ! Really enjoyed are talk.
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4072 |
Posted: 07 Jul 2016 at 11:35pm |
did it come from the factory that perfect , thats a good looking job
Bird76Mojo
Posted: 08 Jul 2016 at 1:30am |
The paint can be protected for years to come for pretty cheap. 3M makes a perfectly clear film that can be applied to anything painted. Much like a high quality cell phone screen protector. It's used quite a bit in the motorcycle world and on the front of expensive automobiles for rock protection.
It's pretty amazing stuff for paint protection from rocks and debris. On a tractor of that quality, I'd make the investment myself... https://www.youtube.com/watch?v=sjU3INHODBQ GB
Orange4ever
Joined: 01 Sep 2014 Location: Farmington, MO Points: 390 |
Posted: 17 Jul 2016 at 5:44pm |
Showed your tractor to my father, he saw something you need to correct he says your return line coming out of your hydraulic valve is going to the top of your tank, that's where you fill the tank up at. That is also to be a vented top. This will cause foam and air to enter your hydraulic tank. Possibly causing pump damage. There should be a place to hook the return line in down low on the hydraulic tank, a few inches above the intake for the pump. The little screw that's in the tank that's above the hydraulic control is the filler indicator, you remove that screw and fill it up to that level. Also check where the return is coming out of the valve, I think you have that hooked into the power beyond, I think it should be coming out of the out port.
If you want a man to be a successful farmer, give him a Allis Chalmers tractor. If you want him to be a successful mechanic, give him a John Deere
mnoonan-NEWI
Posted: 17 Jul 2016 at 10:17pm |
PM sent |
Nate (OH)
Joined: 12 Sep 2009 Location: Bellevue, Ohio Points: 216 |
Posted: 26 Jul 2016 at 6:03pm |
I have 2 in my garage you can make look that pretty!!
