720 - Dual 2 way system on front
den/southern illinoi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote den/southern illinoi Quote  Post ReplyReply Direct Link To This Post Topic: 720 - Dual 2 way system on front
    Posted: 30 Jul 2015 at 9:24pm
I'm working with a person who want to have 2 - 2 way hydraulics on the front of his 720/620/616.  I know that the front has room for 4 outlets and the bracket on the side of the engine is made for 4 lines. My question is where would another control lever and valve go or was it a 2 valve/lever system with one valve controlling one set of front outlets plus the back ram and the other lever controlling the second set of front valves.  I have never seen the set up so I'm guessing this is how it is done.
Den
Own 4 wheel 20, 5020 and associated equipment and 1 electric forklift. Also a 720 garden tractor, 720 Diesel. 620 and soon a 616 garden tractor.
fasstman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fasstman Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2015 at 10:29pm
You need the lines from a single bank valve to add to the dual bank system. Did that on my 720.
coggonobrien View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2015 at 7:08am
the second lever would go right next to the 3pt/1st remote system.
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2015 at 7:10am
https://www.google.com/search?q=allis+chalmers+720+hydraulic+lever&espv=2&biw=1855&bih=744&source=lnms&tbm=isch&sa=X&ved=0CAcQ_AUoAmoVChMI8c_W96qFxwIVhmk-Ch2mMw6C#imgrc=ZUppCtyyE07CvM%3A
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2015 at 7:11am
http://www.allischalmers.com/forum/uploads/140/DSCF4792.JPG
structures View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote structures Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2015 at 8:22am
I've been reading this thread over and over.  Looking at the picture.  I still don't get how it works.
So when you have 4 ports out the front does the second set of ports run off the 3pt lever?  Or can you put 3 levers across the left side?
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2015 at 8:41am
1st set runs off 3 pt lever 2nd set runs off 2nd handle
Post Options Post Options   Thanks (0) Thanks(0)   Quote structures Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2015 at 10:17am
Got it.
