720 Allis Chalmers |
Mike K
Joined: 27 Sep 2009 Location: Edgar, WI Points: 231 |
Topic: 720 Allis ChalmersPosted: 19 Apr 2020 at 10:22pm |
Put my tiller on today. When I try to till in the ground, the motor slows and will not come back. what is wrong with the onan motor.
exSW
Joined: 21 Jul 2017 Location: Pennsylvania Points: 914 |
Posted: 20 Apr 2020 at 8:28am |
Governor? This is a swag answer.
Learning AC...slowly
Steve in NJ
Joined: 12 Sep 2009 Location: Andover, NJ Points: 12071 |
Posted: 20 Apr 2020 at 9:41am |
Mike,
Check your fuel delivery and your air intake. Maybe air cleaner is pluggin' up and not getting enough air. Inspect the spark plugs to. Might need a couple new plugs. (especially if they're Champions) Few easy things to check... Steve@B&B
injpumpEd
Joined: 13 Sep 2009 Location: Walnut IL Points: 5204 |
Thanks(1)
Posted: 20 Apr 2020 at 3:16pm |
Mine loses a lot of power when the points need re-set.
AC720Man
Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5458 |
Posted: 20 Apr 2020 at 3:29pm |
Points is a good place to start, they require to be checked every 100 hours or sooner. I also had a fuel filter slowly clog over the winter last year. Drove me nuts until I saw very little fuel in the clear filter. Replaced it and she ran like a champ.
AC720Man
Posted: 16 May 2020 at 7:33pm |
Well, interesting thing happened yesterday. Got one of my 720’s out for the first time this year. I usually use it to till my garden and run the bush hog. Yesterday while tilling the garden she sputtered about 5 minutes after I began. Came back about 5 minutes later, she started right back up for 30 seconds and shut down again. So, 2 years ago same thing happen. Replaced the fuel filter and off she went and never gave anymore issues. Same thing yesterday, replaced what appeared to be a perfectly good filter. Turned it upside down and a bunch of rust came out. Filter was mostly clogged. New filter and I finished tilling the garden, bush hogged, and used the blade to level some gravel for a patio. Simple fix
AC720Man
Posted: 16 May 2020 at 7:37pm |
Steve in NJ
Posted: 18 May 2020 at 6:28am |
Great pics Rob! I like to see em' workin'. Like I said, that fuel delivery system sometimes bites ya. LOL!
Steve@B&B
8070nc
Joined: 21 Mar 2019 Location: North Carolina Points: 719 |
Posted: 22 May 2020 at 6:26pm |
Id like to know where you got the rotary cutter |
1984 80780
1957 D14 DES 300 with 25000 engine 616 tractor |
AC720Man
Posted: 24 May 2020 at 7:49pm |
Got very lucky. Went to buy another 720 a few years ago. Had a front blade to go with it and a parts tractor that was involved in a garage fire. As I was loading it the fella surprised me and said do you want the ole bush hog that goes with it? I said absolutely, where is it? He said you walked right by it, it’s covered up under that tarp. Needless to say I was ecstatic. I brought it home, sandblasted it, and gave it a paint job. It works great mowing around my fence rows.
Gary Burnett
Joined: 11 Sep 2009 Location: Virginia Points: 3190 |
Posted: 27 Jun 2020 at 6:20am |
I have one I'll sell.Mechanically fine deck needs some work.
