720 Allis Chalmers
Mike K View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike K Quote  Post ReplyReply Direct Link To This Post Topic: 720 Allis Chalmers
    Posted: 19 Jan 2019 at 11:47am
I am about to change fluid in my 720. I need to locate the drain plug for the hdy. I have the filter. How much fluid do I need to have to replace it with, and the correct type
                               Thanks         Mike
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2019 at 1:14pm
I'll be watching this. Bought the filter to change mine last summer, never found the plug!
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2019 at 2:09pm
There is no true drain plug. Remove the transmission temp sensor located in the lower front of the hydro. Bottom pan has to be removed if it hasn’t already removed. Lots of dirt, mice nests typically there. Fluid amount and type is located on the sticker located under the hood. Easy job.
Acdiesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2019 at 2:17pm
see post is garden sectionSmile
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF
D15 SER.2 DIESEL
D12 SER.I, D10 Ser.II
2-720'S D21 Ser. II
Gmc,caterpillar
