720 Allis Chalmers
Message Reverse Sort Order
Acdiesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Topic: 720 Allis Chalmers
    Posted: 19 Jan 2019 at 2:15pm
remove the bottom cover off the tractor (i think 8 bolts ) (if its still there)
at the front bottom of the trans. you'll see a steel tube with a rubber hoes on it, you can remove the hose and unthread the fitting the stand pipe is about 4 inches long when you take it out. you can also remove the trans. temp. sender to help drain, you can jack the back of the tractor up to help in draining.
fluid is: ATF dexron
about 6 qts.
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF
D15 SER.2 DIESEL
D12 SER.I, D10 Ser.II
2-720'S D21 Ser. II
Gmc,caterpillar
Mike K View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike K Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2019 at 11:55am
I am about to change fluid in my 720. I need to locate the drain plug for the hdy. I have the filter. How much fluid do I need to have to replace it with, and the correct type
                               Thanks         Mike
This page was generated in 0.069 seconds.
