720 A.C. will not steer, |
DougG
Topic: 720 A.C. will not steer,Posted: 06 May 2017 at 3:38pm |
Getting my 720 ready for garden work after setting all winter, and it will not steer, can't get no reaction at all to the front steer tires,, I drove it around in circles thinking it may come out of it, nope, any recommendations?
AC720Man
Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5488 |
Posted: 06 May 2017 at 5:10pm |
I am assuming the steering wheel turns? Never heard of that issue. There is a bolt that holds the steering wheel on, several roll pins that attach the universal joints to the steering colunm and to the steering box I believe. Check each of them to make sure one hasn't sheered.
DougG
Posted: 06 May 2017 at 6:33pm |
No , the steer wheel does not turn, took the linkage away from the front end and it turns, acts like it should,, the steering gearbox seems stuck,,
Edited by DougG - 06 May 2017 at 6:37pm |
Acdiesel
Joined: 15 Jun 2012 Location: Rochester Ohio Points: 2592 |
Posted: 06 May 2017 at 7:38pm |
it was working fine when you put it away?
any chance water got in your gearbox somehow froze causing something to break? i remember that mine at one time had a spot in the gearbox where it would bind while i was mowing the lawn, u-joints were o.k. just lubed the gearbox inside and adjusted the free play. if you had a bad u-joint i would think the wheel would turn ever so slightly back -in forth. might be something in the gearbox or steering shaft. dan
DougG
Posted: 07 May 2017 at 10:50am |
Thanks for the responses and ideas, went out there this morning beat on the tie rod a little, took a wrench to the place where the tie rod hooks to the gearbox worked it a little and now it works,, don't kno what was hanging up but she's fine now,, whew, it's always something
AC720Man
Posted: 07 May 2017 at 3:16pm |
Glad you got it figured out! Jut got off my 720 mowing with the sickle bar mower. It did a good job although I couldn't lift it correctly until I get a right side cable made up.
