720 620 616 trans oil
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Topic: 720 620 616 trans oil
    Posted: 04 Mar 2015 at 1:01pm
anyone use power trans. hyd. oil in these tractors
aras View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote aras Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2015 at 1:07pm
I'm rather sure they use ATF
den/southern illinoi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote den/southern illinoi Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2015 at 2:52pm
I use ATF with good luck.  Den
Own 4 wheel 20, 5020 and associated equipment and 1 electric forklift. Also a 720 garden tractor, 720 Diesel. 620 and soon a 616 garden tractor.
coggonobrien View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2015 at 11:20pm
dexron 3
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2015 at 9:07am
one of our customers use hy tran in his 720 in his trans and loader  but i ask becausse we just when through a massey 40 and i put hyd. in the gear pump for the steering an d you could not turn with both hands put atf in and you could turn end of finger the sundstrand pump on the 616 looks like it could go right on ih combine   by the way the customer with the massey had been using brake fluid in the power steering wich mostly was going inthe crankcase so you can guess what the crank looked like
This page was generated in 0.332 seconds.
