716H wont move |
Post Reply |
Djp9211
Bronze Level Joined: 05 Feb 2022 Location: Illinois Points: 5 |
Posted: 05 Feb 2022 at 3:20am |
I have a 716h I used yesterday to blow snow pulled it in the garage went out this morning to hop on it to finish blowing the snow off driveway and it won't do anything when you move forward and reverse. Any help would be greatly appreciated!
oldfords
Bronze Level Access Joined: 31 Mar 2020 Location: South Dakota Points: 46 |
The first thing I would look at is to make sure the two little plungers under the seat are up. They are located under a spring loaded lever that you push down to free wheel the tractor
Mikez
Orange Level Access Joined: 16 Jan 2013 Location: Usa Points: 8143 |
welcome to the forum.
Also some time people push clutch brake in and it sticks, so make sure the belt is tight and is spinning the rear pulley and check oil levels.
Djp9211
I think I found what you're talking about they don't seem to move I took them out to clean but doesn't seem like they come apart should the buttons go down easy or are they stuck? Also have a sound coming from centrifugal clutch and have no pullys spinning
Mikez
with it running the front pulley off bevel gear box should be spinning. If not check drive shaft off engine. There’s round fiber plates that bolt in between each end of drive shaft. Or maybe bevel gearbox is out.
Mikez
if your belt isn’t spinning it’s not the buttons. And yes they do stick if you don’t use them. Soak them in penetrating oil
Djp9211
The drive shaft spins but nothing after that is.turning
Mikez
bad news then. That gear box is out. And it’s expensive to rebuild. But in my opinion worth fixing the ole girl
Djp9211
I was afraid of that. Any idea how hard it is to rebuild or replace? Or where to find a new one?
Mikez
well do you have an old small engine repair shop with experience with them. Or you working on it yourself. If you don’t have parts books, you can look up parts tree. Type in 7016 and look for simplicity and look for bevel gear box. A lot of folks on here use sandy lake implement and ask for Brenda
Edited by Mikez - 07 Feb 2022 at 1:35pm |
DaveWisc.
Orange Level Joined: 11 Oct 2009 Location: Wisc. Points: 960 |
Idk bye could you just replace the box easier
ac55tractor
Silver Level Joined: 20 Oct 2012 Location: Raymond, Maine Points: 240 |
I just searched around for a pair of gears for you. They are not cheap.
You may be better off finding a replacement bevel gear box. They made different boxes for these tractors. Just be careful what you choose. eBay has one for about the price of new gears. I am not recommending that you buy anything. I am just showing you examples. Send me a personal message. I will send you back my email and I will forward a parts manual and operators manual to you. I just tried to send them through the forum, they wouldn't go. Glad to help I have 4 Simplicity Garden tractors here at the house. I have kept them all running for over 25 years now. Simplicity 3510 Simplicity 7013S Simplicity 7016 Simplicity 7016H Steve (in ME) |
Post Reply | |
