716H with 919 snowblower |
dnel45
Joined: 13 Oct 2009 Location: Northwest Ohio Points: 164 |
Topic: 716H with 919 snowblowerPosted: 10 Dec 2014 at 2:41pm |
Will a snowblower from a 919 series fit on a 716H? How about a front snow blade? Thanks.
Steve in NJ
Joined: 12 Sep 2009 Location: Andover, NJ Points: 12071 |
Posted: 10 Dec 2014 at 3:24pm |
I don't see why not. I believe the frames are the same, and I think they utilize the same type of pto setup off the front of the crankshaft. Front snow blade should be the same also. Make sure you have an electric lift. I know that Dozer blade is one heavy dude! That would wear ya out having to pick that up emanuel. Same goes for the snow blower..
Steve@B&B |
Steve in NJ
Posted: 10 Dec 2014 at 3:40pm |
Here's the wife having a ball on our 716H with snow blade. Awesome machine!!
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4070 |
Posted: 10 Dec 2014 at 4:51pm |
little tip if your manual lever operates the rear hitch at the same time like my 101 i hang a front wheel weight off a wd couter weights the snowthrower and makes it almost zero effert on the manual plus helps on traction. by the way thats a sharp rig there
