716 Puller
KevinON View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KevinON Quote  Post ReplyReply Direct Link To This Post Topic: 716 Puller
    Posted: 07 Aug 2014 at 9:03pm
I have changed the size of the rear pulley on my son's 716 puller to alter the ground speed. There never was a rear belt guide over the original pulley. It is almost impossible to change gears on this thing. Any ideas to solve this issue?? Thanks.
farmtoybuilder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmtoybuilder Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2014 at 6:55am
You can make one out of thin flat strap and bend to pulley diameter and weld mounting tabs to it and fasten to side transmission. Adjust to about 1/8'' clearance around the pulley. Or you can use a few L shaped rods and place in 2-3 spots to do same. Make sure it has top belt stop-guide on also. Rods would wok best for puller if your changing diameter of rear one from time to time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KevinON Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2014 at 11:56am
Thanks, farmtoybuilder! I was considering that.
