716 mower deck?
jorstad brothers View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jorstad brothers Quote  Post ReplyReply Direct Link To This Post Topic: 716 mower deck?
    Posted: 06 Jul 2016 at 6:37pm
my 716 mower is not pulling the grass up from the front wheel tracks.
i have done several things nothing helps. any advice.
Edited by jorstad brothers - 06 Jul 2016 at 6:37pm
remember plunder than burn
ACmowerguy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACmowerguy Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2016 at 9:26pm
Have you leveled the deck so that the front tip of the center blade is 1/4" higher than the rear tips of the outer blades? It is not unusual for the 48" decks on the Sovereigns to have some wheel track problems. Cutting slower or at a lower setting may help, though cutting lower is worse for your lawn. Narrow front tires may also help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jorstad brothers Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2016 at 10:04pm
i did level the deck so the outer blades are 1/4 higher in the front. it has new rollers and rod,blades spindle bearing spindle pulleys and belt.
19856020 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 19856020 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2016 at 4:05pm
only other reasons that have not been mentioned that have happened to me, grass too tall or wet . if you discover anything else I would sure like to know , I have 3 of these decks and if blades are in good condition they mow perfect . way way better than any green n yellow machine
716 917 918 1920 d17 6080
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2016 at 6:57am
Is your inside baffle still intact
This page was generated in 0.456 seconds.
