715B - Perkins engine starter
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Topic: 715B - Perkins engine starter
    Posted: 05 Aug 2025 at 12:35am
Just got a starter off E-bay for the Perkins - I was having problem with engagement in flex plate and found the starter drive gear was worn down and not fully engaging .
 I also replaced 2 nose cones on starter over the years that cracked .
 So Chinese Starter and $130 for new one - might have got by with just replacing the drive on old unit a little cheaper but was getting tired of swapping parts in my old Delco units .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2025 at 11:15am
New Chinese starter in and it works good so far , old unit did not throw into starter ring and on looking at old starter drive it was worn from not totally engaging the flex plate teeth .
 Only problem was the supplier said 3 day delivery and it ended up 15 days - so much for some suppliers on E-bay
