715B - Perkins engine starter |
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42246 |
Topic: 715B - Perkins engine starterPosted: 05 Aug 2025 at 12:35am |
Just got a starter off E-bay for the Perkins - I was having problem with engagement in flex plate and found the starter drive gear was worn down and not fully engaging .
I also replaced 2 nose cones on starter over the years that cracked . So Chinese Starter and $130 for new one - might have got by with just replacing the drive on old unit a little cheaper but was getting tired of swapping parts in my old Delco units . |
Coke-in-MN
Posted: 10 Aug 2025 at 11:15am |
New Chinese starter in and it works good so far , old unit did not throw into starter ring and on looking at old starter drive it was worn from not totally engaging the flex plate teeth .
Only problem was the supplier said 3 day delivery and it ended up 15 days - so much for some suppliers on E-bay |
