715B Loss of swing and steering
Dklsc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dklsc Quote  Post ReplyReply Direct Link To This Post Topic: 715B Loss of swing and steering
    Posted: 28 Oct 2024 at 7:16pm
Finally got the shuttle transmission rebuilt and put back in and I have Forward and Reverse !!
However I have lost the swing and steering, (worked when parked) I see they share a common supply through the swing valve. I have pulled the relief valve and it was clean and not stuck. Everything else works good. Any suggestions where to look next? Thanks
KRAKMT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KRAKMT Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2024 at 11:30am
I have a 715b but have not had to tear into the hydraulic circuit, yet.
Here is a good discussion of something similar.
https://www.allischalmers.com/forum/ac-715d-backhoe-hydraulic-pump_topic96342.html
I was thinking that the pump was two circuits.
If you are full of fluid, and have checked the suction screens, it might require a pump refresh but this place has good mechanics that will answer your question better than me.
