715B hyd pump brace
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Topic: 715B hyd pump brace
    Posted: 15 May 2012 at 2:12pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2012 at 2:15pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2012 at 11:41am
Unsure of what the updated brace from AC looked like but i worked out this piece to stop the hyd pump vibration and load on the timing cover from cracking it again. I bought the machine from city near here and they had replaced one cover and the one they put on cracked again and at time of sale they had another new cover but had not put it on.
 I made up brace and used silicone for 5 years to keep the leak from cracks from being a problem then did a replacement of the front casting and re-installed brace, so far no cracks or leaks since and has been 10 years now . It's a simple bar with a U clamp to go onto pump hyd fitting to keep the weight of pump supported and to keep the strain from hoses from transferring to the timing cover.
orangeman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2012 at 5:19pm
Coke: Nice work, would like to have a 715 or 816 some day.
Dave A View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave A Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2012 at 6:35pm
does that pump run the loader or just the stearing
Play the game for more than you can afford to lose... only then will you learn the game.
Winston Churchill
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2012 at 6:48pm
The pump runs everything but the fwd-rev, hydraulic steering with char lyn orbital hyd steering motor and cylinder on tie rod
 AC came out with a update but unsure of what it was , I just looked at the problem and seen those 2 holes back on bell housing and had a extra trailer hitch tongue with a little offset bend , and it works , see the chrome is peeling though .
Edited by Coke-in-MN - 01 Jun 2012 at 8:47am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave A Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2012 at 8:36pm
I thought of running my steering off of the front hydo pump. I can see why the housing cracks on these tractors. The engine has movement and the suction hose is short and heavy. Orangeman I might have a 816 for sale in the near future. The guy down the road has a bigger toy for sale
We all know how the song goes . Faster horses, older whisky, younger woman, and more money
Edited by Dave A - 29 May 2012 at 8:53pm
Winston Churchill
