715B Cutting Edge
Message Reverse Sort Order
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Topic: 715B Cutting Edge
    Posted: 05 Mar 2019 at 7:41pm
Should be able to source from most steel supply houses or other equipment dealers - depending if weld on or bolt on .. either way should be a local item you can find
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2019 at 5:57pm
You might try stephens equipment, near Pitsburgh, PA...
JimWenigOH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimWenigOH Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2019 at 5:23pm
Time to replace mine. Anyone have a source for one of these?
