715b Backhoe..what is the year
joe22 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote joe22 Quote  Post ReplyReply Direct Link To This Post Topic: 715b Backhoe..what is the year
    Posted: 27 Dec 2014 at 8:03pm
Hi guys I have a 715b backhoe with a 2534 serial number but I don't know what year it is, so I can get the correct books on it .im having a problem with the injector pump leaking on the throttle rod any sugestions... I think there must be a o ring inside but don't know if it can be fixed without removing the pump. thanks for any help
Joe
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2014 at 10:55am
Your 715B is a 1979.  The engine is a 236 Perkins. Parts are readily available for the engine from any Massey dealer. I've had a 1981 715B since 1987 and a 715 before that.
They are a very good realiable machine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote joe22 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2014 at 11:22am
Thanks So much I have been searching hi and low im very grateful to you.I love it have had no problems except the leaking fuel. I have a parts catalog for a 1982 .... is the will this be the same for a 1979? thanks for all the help.it looks like just the o rings on the injector pump accelerator rod that are leaking wondering if there is a kit for just that or does the whole pump have to come of . thanks for the info Joe
Post Options Post Options   Thanks (0) Thanks(0)   Quote joe22 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2014 at 11:25am
Also I see you are from Canada and was what you do when starting it when its cold out, thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2014 at 12:27pm
To my knowledge there were no changes in the 715B's throughout their production so your 1982 book will be good. My 715B rests for the winter and has been a farm machine after years of digging silo foundations. The engine is getting very tired. The best way to start it in cold weather is to have a block heater. A LITTLE starting fluid is also very effective in these engines.
Post Options Post Options   Thanks (0) Thanks(0)   Quote joe22 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2014 at 12:32pm
thanks for all your insite thanks again Joe
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2014 at 12:51pm
Plan on a can of starting spray for any time it is cold ,
If you can plug it in it helps also but many times mine was some where power wasn't handy
Post Options Post Options   Thanks (0) Thanks(0)   Quote joe22 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2015 at 4:04pm
Would anyone know what the weight would be for a 715b backhoe for transportation purposes thanks Joe
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2015 at 9:03am
Sales literature does not list the weight but my guess is close to 12,000 lbs.
Yooper Rod View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Yooper Rod Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2015 at 11:45am
According to the owners manual, the weight with the 7/8 loader, 24 inch backhoe bucket, and 11L-16 front and 16.9-24 rear tires, the shipping wt is listed as approximately 13,000. It appears that this is foe an open canopy.
This page was generated in 0.158 seconds.
