715B Backhoe please help
NEK715 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEK715 Quote  Post ReplyReply Direct Link To This Post Topic: 715B Backhoe please help
    Posted: 14 Jul 2010 at 1:44pm
Hello,
I bought a 1979 715b backhoe, the transmission dipstick is broken off (not inside trans) I need to make a new dipstick and wanted to know how log it needs to be.
Could someone out there with an Allis 715b backhoe please measure the transmission dipstick (not including the handle and cap, just the thin metal strip) and post the length on here.
Thanks
Dave A View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave A Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2010 at 9:20am
might be able to buy one
Play the game for more than you can afford to lose... only then will you learn the game.
Winston Churchill
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEK715 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2010 at 9:33am
I have never seen obe before for sale and I can just as easily make one if I have the length.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2010 at 11:24am
Dipstick is 30.75" long as measured from the disc with the O ring. The ADD mark is 1/2" from the end and the full mark is 1/2" higher. The fluid level is much higher after sitting for awhile. You are supposed to check the level immediately after shutting off the engine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEK715 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2010 at 11:32am
Thank you,
This saved the day!!
