715 backhoe
ILGLEANER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ILGLEANER Quote  Post ReplyReply Direct Link To This Post Topic: 715 backhoe
    Posted: 14 Jul 2024 at 10:07pm
Is it possible to put a 433 in a 715 that has the Perkins? The motor is tired and l have a 433 that is a stationary motor with clutch and shaft out of the bell housing.
    TIA
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2024 at 12:46am
Anything is possible - with enough time , work and money .
Seems a couple different engines were used in the 715 , over it's lifetime
Mating the torque converter to a flywheel or flex plate and then adapting engine to fwd-rev box might be a problem - though that same unit was matched to many different marine units like 71 Series Detroits .
Jun 22, 2021 — I am just wondering about switching it out with another Perkins 236 from a Massey tractor. ... Perkins made many different blocks, pans and such ...
KRAKMT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KRAKMT Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2024 at 4:44pm
Given the 236’s life in marine, I found good support for Perkins parts. And several offers for used 236 engines from board members.
