715 backhoe trouble
ILGLEANER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ILGLEANER Quote  Post ReplyReply Direct Link To This Post Topic: 715 backhoe trouble
    Posted: 03 Dec 2014 at 9:19pm
When you go forward or reverse it makes a howling screeching noise. Don't believe it to be in the transmission. The gears shift fine. Would it be the tourqe converter?
             IG
dustinmo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dustinmo Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2014 at 10:37pm
I cant answer your question but if it turns out to be that get ahold of me as I have a complete engine and torque conv setup in the shed from waterpump to bell housing in the shed out of a 715 hoses wiring and all ,  was cut out of the machine with a torch as trans went bad and guy was going to scrap it and would have if I would have been a day later,  been looking for a 715 with bad engine or a 170-175 but havent found one and probally wont until I get rid of it or parts
Post Options Post Options   Thanks (0) Thanks(0)   Quote dustinmo Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2014 at 10:41pm
you might look at trans as the one I bought parts off of had the cluster shaft come loose and back out enough to let front of cluster fall down and wore the teeth off cluster and imput,  worn or improperly meshing teeth will howl
Post Options Post Options   Thanks (0) Thanks(0)   Quote ILGLEANER Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2014 at 8:10pm
Thanks for the heads up . I will keep you in mind.
       IG
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2014 at 12:26pm
torque converter and the fwd/rev box both ahead of trany so would be looking there.
Dave A View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave A Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2014 at 5:14pm
Dustin is that a Perkins engine would you have the stear hyd pump
Edited by Dave A - 20 Dec 2014 at 5:15pm
Play the game for more than you can afford to lose... only then will you learn the game.
Winston Churchill
Post Options Post Options   Thanks (0) Thanks(0)   Quote dustinmo Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2014 at 5:38pm
yes it is a perkins and it has all hyd pumps attached,  call me and we can figure out if it is the same, Dustin 573-592-9205
