715 backhoe forward/reverse |
Ages Cat
Joined: 12 Sep 2009 Location: Hutchinson, MN Points: 700 |
Topic: 715 backhoe forward/reversePosted: 04 Feb 2018 at 10:22am |
I have a new shop manual for 715B s/n 2045 and up. $35.00 shipping included.
Curt Anderson
HD3, HD5B, HD6AG,HD6B dozer, I-400,615, 616,620,720,ACP25 lift truck, 1956 D Grader, AC 540 loader, AC #84 plow, Simplicity tractors, Agco MT225, Agco 2025, |
Orange4ever
Joined: 01 Sep 2014 Location: Farmington, MO Points: 390 |
Posted: 03 Feb 2018 at 7:30pm |
We have 816 backhoe did ours twice since 78 if you have the book it is really easy
If you want a man to be a successful farmer, give him a Allis Chalmers tractor. If you want him to be a successful mechanic, give him a John Deere
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42263 |
Posted: 02 Feb 2018 at 5:45pm |
The transmission is a Borg Warner 4 speed box - the fwd / rev unit is a hydraulic clutch pack with a torque converter in front - there are pressure rating measurements to help identify problems also in repair manual
AC7060IL
Joined: 19 Aug 2012 Location: central IL Points: 3670 |
Thanks(1)
Posted: 02 Feb 2018 at 10:30am |
Yikes!!! |
Coke-in-MN
Posted: 02 Feb 2018 at 9:44am |
Someone on here listed a kit for the clutch pack back when i was having problems - believe they were out of Michigan
The fwd/rev clutch pack is bad - needs rebuilding R&R is suppose to be about 10 hours according to book . It's a common problem and one of items that needed repair . Fwd goes bad and reverse will still work some - and yes 4th and 3rd lose power to drive and the more its used the more the clutches wear and fail Ah yes - I needed my machine so had a Ford Dealer (Carleson Tractor of Rosemount MN) who said they could do it repair mine while i rented a machine from them to finish jobs i had - I had a spare parts kit from when i bought the machine so gave them my manuals and parts - (they are now out of business) Took them over a week to repair - charged me 40 hours labor + rental for transmission jack - said kit was short 3 "O" rings which they charged $80 for . Got in quite a hassle with their shop foreman - he questioned if my check was any good - I questioned his legal birth - but as they had my machine and i needed it I paid . Unit went bad again within 25 hours of use ( $4000 down the drain to crooks ) Same outfit went after my oldest son for some bill they said he had - took him to conciliation court in 3 different courts - different counties - then here in Wash Co - judge here dismissed all charges with prejudice - told them he would recommend to my son to file harassment charges in District Court against the dealership and owners . Edited by Coke-in-MN - 02 Feb 2018 at 9:58am |
Dgrader
Joined: 17 Jan 2015 Location: Newton,IL Points: 1037 |
Posted: 02 Feb 2018 at 9:11am |
Don't remember the make an model # on it. Should be a tag on the tranny.
Ya cain't fix stupid.
Dgrader
Posted: 02 Feb 2018 at 9:08am |
Our 715 lost all gears but 2nd. Took it out and couldn't find the gears to rebuìld. Found a used one on craiglist for 500. Not a bad swap to do.
FarmerBrawn
Posted: 01 Feb 2018 at 10:54pm |
Have a 715 backhoe. Forward works pretty good when transmission warm but in cold weather does not want to lock up and only moves in reverse. I can get it to go forward but it is slipping. 4th gear has always slipped. 3rd won’t pull a hill.
I am assuming an overhaul will be in order. What is the model so I can check with local guys to setup overhaul? |
