715 B |
Chris Dame
Joined: 11 Apr 2023 Location: Grovespring Mo. Points: 8 |
Topic: 715 BPosted: 12 Apr 2023 at 9:58am |
Looking for valve assembly for 715D part #1002958 if anyone could help
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35625 |
Posted: 11 Jul 2020 at 2:21pm |
Do not know if Case did but the Fiat Hitachi versions seemed a close second upgrade.
KRAKMT
Posted: 11 Jul 2020 at 12:09pm |
Anyone know if case made a model that was a direct copy of the 715b?
At least as it applies to the swing cylinders? https://www.brokentractor.com/c/case-backhoe/hydraulic-cylinder/swing-cylinder-parts/ Edited by KRAKMT - 11 Jul 2020 at 12:12pm |
KRAKMT
Posted: 11 Jul 2020 at 11:50am |
I took hoe swing cylinders in to hydraulic shop.
Estimate $1800 per cylinder for repairs. One has a broken piston, the trunnions are egg shaped, the eyes are egg shaped. Any one have a spare piston? |
KRAKMT
Posted: 11 Jul 2020 at 11:47am |
I just happened to have used Joseph and did replace pump plate and converter.
They were cheapest, shipped fast and good to work with. |
david a
Posted: 10 Jul 2020 at 4:33am |
https://www.joseph.com
Edited by david a - 10 Jul 2020 at 4:34am |
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42261 |
Posted: 10 Jul 2020 at 12:04am |
your link to Joseph doesn't seem to work
Ages Cat
Joined: 12 Sep 2009 Location: Hutchinson, MN Points: 700 |
Posted: 09 Jul 2020 at 10:20pm |
Regarding AC yellow, I was told the paint used on late AC machines was national school bus yellow. I am using a Hentzen products on our AC industrial machines. This information came from Cook Sales & Service in Missouri.
Curt Anderson
HD3, HD5B, HD6AG,HD6B dozer, I-400,615, 616,620,720,ACP25 lift truck, 1956 D Grader, AC 540 loader, AC #84 plow, Simplicity tractors, Agco MT225, Agco 2025, |
david a
Posted: 09 Jul 2020 at 7:15pm |
https://www.joseph.com I got my torque converter from this web site. just been down this road. You might want to replace the front pump and forward piston. It might be cracked. I have the repair manual if you need info
Coke-in-MN
Posted: 21 Jun 2020 at 8:02pm |
the cylinders are trunion mounted with the mount about centered on cylinder barrel , they do have a bushing kit for these as I replaced mine when I replaced other bushings on the hoe . Again Minn-Par should have the parts
KRAKMT
Posted: 16 Jun 2020 at 10:06pm |
I was hoping to shut off leakage.
I took the two swing cylinders in for rebuild. If anyone has tips, tricks or recommendations for bushings for the swing pins and the rod ends, I could use the help. I will try a machine shop but open to options. |
DMiller
Posted: 14 Jun 2020 at 7:44am |
Why shut off fluid flow? Does not accomplish anything if not using functions of the hoe.
KRAKMT
Posted: 14 Jun 2020 at 7:30am |
I blew a hose as I was lifting out a pit I made to roast a whole pig.
Which then caused me to pull both swing cylinders. Hopefully this week I can get the cylinders rebuilt and reinstalled. I may still install a valve to isolate the hoe since I got everything apart. |
Coke-in-MN
Posted: 07 Jun 2020 at 12:54pm |
They make a hydraulic Push / Pull 2 port diverter valve for separation had one on my HD4 for hoe or bucket , on my 715 B there was one in hoe system as they ran a hammer also on the hoe .
KRAKMT
Posted: 06 Jun 2020 at 7:28am |
Hey hydraulic experts. Spent some time and money on the 715 this month but have some deferred maintenance that I would like to defer a little longer. The swing cylinders on the backhoe are leaking pretty badly. I have several other tasks to do before tackling them. Several years ago I replaced the canister hydraulic housing filter with a screw on filter and replumbed from the pump back to the controls. I am wondering if I can put a valve in the line after the tee intersection that diverts flow to the fel? This would shut off flow to backhoe when not in use? Suggestion for ball valve? Thanks for the help. |
Coke-in-MN
Posted: 03 Jun 2013 at 5:54pm |
a ![]() b ![]() c ![]() |
Coke-in-MN
Posted: 18 Sep 2011 at 8:53am |
I will see if i can get picture of the one I made , unsure what the factory used . I used the chrome tongue of a old trailer hitch . It runs from bellhousing up to rear of hyd pump. and fastens onto fitting there with a clamp. 2 bolts into bellhousing and that U clamp to pump keeps it ridgid. |
KRAKMT
Posted: 18 Sep 2011 at 8:43am |
Dnoyn -great thanks- getting closer to needing a bit o paint.
K |
KRAKMT
Posted: 18 Sep 2011 at 8:42am |
Just north of Billings but I grew up in ND. Spent many years digging trenches by hand- probably the main reason for owning a backhoe.
K |
Dnoym N. S. Can.
Posted: 18 Sep 2011 at 8:17am |
http://paintref.com/cgi-bin/colorcodedisplay.cgi?manuf=Allis%20Chalmers
they change a lot of the codes since back then if you need more help let me know B:-) Dnoym |
darrel in ND
Joined: 22 Nov 2009 Location: Hebron, ND Points: 8776 |
cool project, KRAK. What part of MT you from, if you don't mind my asking? Darrel
KRAKMT
Posted: 17 Sep 2011 at 9:40pm |
My 715B lives- took it down to get the mail this afternoon!
It has taken me awhile but I finally replaced the torque converter, pump and rebuilt the shuttle- and it works! Prior owner must have stacked the pump because the shuttle looked good but I still replaced the clutches. Converter and pumper were trashed. If I was to do it again, heaven forbid, I think I would cut out the rear tranny/engine mount and retrofit in a bolt in brackets. I mention this for the few people that have posted and the apparent common repair need. With the mounts as they are welded to the frame the shuttle/bell housing can only slide back a few inches. Makes sliding the tranny/shuttle/torqueconverter/bellhouseing damn difficult. I noticed a front cylinder leaking-that will be next. I also noticed a leak out the bottom of the pump- does anyone have a picture of what the frequently mentioned additional pump support bracket looks like? so I can see if I have one. If not any idea where to get one? |
Coke-in-MN
Posted: 23 May 2011 at 8:07am |
believe CAT now has controlling ownership of Perkins
KRAKMT
Posted: 22 May 2011 at 9:26pm |
Pulled the trans/shuttle shift and am having a rebuild kit put in.
When I pulled the torque converter the flex plate was broke in a 1/2 dozen pieces(explains the rattle) and the torque converter looks like someone took a grinder to the mounting hole brackets. The front fingers look like it was not mounted to the shuttle shift right and are ground down some. Any suggestions on torque converter rebuild companies? I notice the flex plate was stamped CAT. |
Calvin Schmidt
Joined: 11 Sep 2009 Location: Ontario Can. Points: 4582 |
Posted: 08 Jun 2010 at 10:46am |
Here is my modified farm version with extend-a-hoe.
Kipn
Joined: 12 Sep 2009 Location: Tewksbury, Ma Points: 800 |
Posted: 08 Jun 2010 at 9:56am |
There are several paint codes for Allis yellow. As far as I can tell, nobody bothered to write down what code was used for what years. Somebody suggested they used what ever supplier was cheapest at the time. I mixed a gallon of what I thought looked good/right.
1961 H3
Coke-in-MN
Posted: 07 Jun 2010 at 9:59pm |
KRAKMT
Posted: 07 Jun 2010 at 2:02pm |
Does anyone know the paint code for Allis Chalmers Industrial equipment Yellow? Will try to paint up parts as I go along.
K
KRAKMT
Posted: 06 Jun 2010 at 2:54pm |
I think I got my photo resized I will give it a try. Still a little large for the screen. Working on putting the old hoe back together. Have replaced filters and fluids. But the shuttle shift appears warn out, as she has no movement. I got it from a good friend's dad's estate. |
