715 B backhoe steering issues
ILGLEANER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ILGLEANER Quote  Post ReplyReply Direct Link To This Post Topic: 715 B backhoe steering issues
    Posted: 09 Jan 2014 at 8:49pm
This fall I was using it. Blew a seal on the hoe cylinder. Lost alot of hydraulic oil. Fixed the seal. Backed it in the shed.3 months later (today). I start it. Put in 10 gal of hydraulic oil. Everything works great. Even before I topped the oil off. But the steering. Was working fine when parked. Suggestions ?
               IG
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2014 at 9:08pm
Air bound steering ? What hose did you blow ? Have had several loader and hoe hoses go bad on mine and never lost steering but then mine has a tendency to wander some and when correcting it soon wheel has turned 90 deg - 180 deg  or a full 360 before some roading jobs are finished .
 You could have picked up air or dirt into steering motor - check for pressure on supply side and also on cylinder for steering
Edited by Coke-in-MN - 09 Jan 2014 at 9:10pm
This page was generated in 0.484 seconds.
