715 B backhoe steering issues |
ILGLEANER
Joined: 13 Sep 2009 Location: Willow Hill,ILL Points: 6448 |
Topic: 715 B backhoe steering issuesPosted: 09 Jan 2014 at 8:49pm |
This fall I was using it. Blew a seal on the hoe cylinder. Lost alot of hydraulic oil. Fixed the seal. Backed it in the shed.3 months later (today). I start it. Put in 10 gal of hydraulic oil. Everything works great. Even before I topped the oil off. But the steering. Was working fine when parked. Suggestions ?
IG |
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42268 |
Posted: 09 Jan 2014 at 9:08pm |
Air bound steering ? What hose did you blow ? Have had several loader and hoe hoses go bad on mine and never lost steering but then mine has a tendency to wander some and when correcting it soon wheel has turned 90 deg - 180 deg or a full 360 before some roading jobs are finished .
You could have picked up air or dirt into steering motor - check for pressure on supply side and also on cylinder for steering Edited by Coke-in-MN - 09 Jan 2014 at 9:10pm |
