712h only runs with full choke when PTO is on
Seth Souerdike View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Seth Souerdike Quote  Post ReplyReply Direct Link To This Post Topic: 712h only runs with full choke when PTO is on
    Posted: 18 Jun 2016 at 3:24pm
So our 712h when mowing (PTO engaged) will only run when the choke is left wide open. Other than that it's fine. Any ideas?
There are no atheist in foxholes.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2016 at 9:47pm
Plugged air filter?
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2016 at 9:47am
carb needs cleaned real well
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2016 at 1:06pm
Yeah, I'm wit' Hud on dat one. You have dirt or varnish pluggin' up the enrichment nozzle making the engine run real lean. Pullin' the choke closed most of the way fattens the mix, and cut off the air charge. Time to "rooto rooter" the Carbatrator....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Seth Souerdike Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2016 at 9:10pm
I'd just as soon by a new carb, know where to get one?
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2016 at 10:53pm
still buy new ones from kohler we have ordered a few in for some of our customers  but i would put new throttle shafts in and bushings if needed and re biuld it all the parts are available
427435 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2016 at 10:45am
You might try running some Sea Foam through it. There are full load mixture adjustments on my gas garden tractors, also. Run it all the way in to get rid of anything that might be in the orifice and then back out to where it was. If still won't run well, back it out some more.
Edited by 427435 - 08 Jul 2016 at 10:46am
Mark
B10 Allis, 917 Allis, 7116 Simplicity, 7790 Simplicity Diesel,
GTH-L Simplicity
Ignorance is curable-----stupidity is not.
