712 Shuttle Transmission Fluid Change
Albow44 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Albow44 Quote  Post ReplyReply Direct Link To This Post Topic: 712 Shuttle Transmission Fluid Change
    Posted: 12 Dec 2020 at 6:03pm
So, I emptied the tranny fluid on my Shuttle, but I'm having a helluva a time filling it back up. Seems like it doesn't want to go through the elbow or something. Anyone have any tips?
Doug Acord View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Doug Acord Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2020 at 6:23pm
There should be three plugs on the side of the transmission the bottom is the drain middle is the level plug and the one behind the pulley at the top is the fill. I have always fill at the top with middle removed and when the oil ran out the that plug the trans was full.  I have use the one quart bottle and squeezed the oil in the side behind the pulley.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Albow44 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2020 at 8:54pm
Thanks Doug, that did it.
