712 S L & G tractor oil capacity question
Jim Hancock View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Hancock Quote  Post ReplyReply Direct Link To This Post Topic: 712 S L & G tractor oil capacity question
    Posted: 29 Mar 2016 at 6:31pm
Hi
Just a quick question for double checking.
I see that it calls for 4.5 pints of 90w oil, which, I've put in.
Does this amount come up to the fill hole, or not?
Thanks. Jim
How blessed we are by HIS GRACE!
ACmowerguy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACmowerguy Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2016 at 10:23pm
It should come up to the fill hole just above the drawbar on the R.H. side.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Hancock Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2016 at 10:32pm
Thanks. I kinda wondered about that.
Looks like I'll be adding some more as it didn't come out of the fill hole.
The only way that I've found, so far, to get oil in there is a 1/4" flexible tube that I hold on the end of a qt. bottle with the pointed cone top, and squeeze.
There's only about 2-3 " of space in front of that fill hole.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACmowerguy Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2016 at 10:26pm
I put a small street elbow into the hole and fill through it.
This page was generated in 1.129 seconds.
