7114 motor options?
yardiron View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote yardiron Quote  Post ReplyReply Direct Link To This Post Topic: 7114 motor options?
    Posted: 24 Sep 2019 at 7:43am
Has anyone ever re-powered one of these using a BS opposed twin?
I've got a good used motor here just sitting on the shelf and figured the 7114 may be a good home for it even if I just use it for yard work and pulling a trailer around.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2019 at 5:42am
I'd snag it for $50 and have another 'Winter project'....
Post Options Post Options   Thanks (0) Thanks(0)   Quote yardiron Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2019 at 3:08am
I took the drive down there Wed, turns out he had a few tractors for sale. I ended up coming home with what I think is a complete 7116. Its got a red hood with no decals. Its definitely a 7100 series, just not sure which model it started life as. Its got a 16hp cast iron Briggs, (gear starter version), and a set of tire chains.  Its going to need a battery and a carb clean but I was able to run it on a can of carb spray and a jump start when I got home.
Its got to be one of the cleanest tractors I've had, no rust, perfect steering, a good seat, four rot free tires,  and even decent paint.
It didn't have a deck but its got a rear hitch and lift, and I bought a complete snow plow set up for it from another seller for $75 on my way home.
I have a guy coming tomorrow to buy the 16 BS twin, selling that will offset half of what I spent.
He had about a dozen Simplicity machines there, and a few green one's too.
Some with motors, some without. The 7114 was nice, but I figured why mess with making something fit when for a little more cash I have something that's nearly turn key for $500.  I figure I'd have spent that much in time alone just making the 16 twin fit the other tractor, only to have something that likely wouldn't be sell-able down the road having a retro fit engine in it without the ability to use many front PTO drive accessories.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2019 at 6:13am
sounds like you did real good ! A 'running' project, er  'field ready tractor'.
The older you get , you realize while you may have money in the bank it's TIME that you're running out of...sigh..
I've started eliminating projects,stopped 'fixin and flippin' and don't repair machine for others...still have too much on my plate AND Mr. Sun doesn't get here til AFTER 7....
sniff.
