71 chevy pickup truck |
Pat the Plumber CIL
Joined: 11 Sep 2009 Location: Springfield,Il Points: 4988 |
Topic: 71 chevy pickup truckPosted: 27 Sep 2023 at 6:00pm |
At least it is the right color. Owner is a customer of mine that I have been working for this week. Claims it has a 8 foot 6 inch bed . Same as a camper special. It has an original Longhorn name plate towards the back of the bed .Never seen one before. He claims chevy made 3000 of them .
1964 D-17 SIV 3 Pt.WF,1964 D-15 Ser II 3pt.WF ,1960 D-17 SI NF,1956 WD 45 WF. |
Codger
Posted: 27 Sep 2023 at 6:24pm |
He is correct.
That's All Folks!
AllisFreak MN
Joined: 07 Dec 2009 Location: Minnesota Points: 1619 |
Posted: 27 Sep 2023 at 7:10pm |
Nice ride. I love that 69-72 body style.
DaveKamp
Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 6124 |
Posted: 28 Sep 2023 at 1:33am |
I second Codger, he IS correct. GM made extended wheelbase chassis, particularly in the 30-series (one ton) for camper use... usually they were single rear, not dually. They didn't always use the 'camper special' moniker, but if they had a low-order year, would fit a factory-stretched pickup bed like this Longhorn... and then send them out to dealers to offer as 'specials'. I happen to have a 1974 1-ton with long wheelbase AND an 11.5' STEPSIDE bed, and like Pat's buddy's Longhorn, there were only 3412 of this spec made. In case of mine, I believe that most of the unordered long chassis trucks may have been offered out as cab-and-chassis, but mine clearly not, as it has a really unique, but positively factory step-side bed. There's a whole lotta 'cool' factor in these things.
Gary
Joined: 13 Sep 2009 Location: Peterborough,On Points: 5911 |
Posted: 28 Sep 2023 at 4:59am |
Link to pictures of some Chevy 'Longhorns'
https://www.google.com/search?q=picture+chevy+longhorn+for+sale&sca_esv=569101513&sxsrf=AM9HkKnabY48hg3JlIMYF_EviL-pdsHYrg%3A1695894904713&source=hp&ei=eE0VZbj1KJCv5NoPyb68uA8&iflsig=AO6bgOgAAAAAZRVbiPgd-UCTnmWnAIrnG8VXDzoomuhF&oq=Picture+Chevy+Longhorn+&gs_lp=Egdnd3Mtd2l6IhdQaWN0dXJlIENoZXZ5IExvbmdob3JuIEgAUABYAHAAeACQAQCYAQCgAQCqAQC4AQzIAQA&sclient=gws-wiz&ved=0ahUKEwi4kfrqhM2BAxWQF1kFHUkfD_cQ4dUDCBQ#vhid=8TF9mJDQLwAyeM&vssid=l -------------------------------------------------------- Longhorn info: https://www.facebook.com/mecumgonefarmin/posts/the-longhorn-truck-was-produced-from-march-of-1968-until-1972-in-1972-there-were/2575701612707423/ Edited by Gary - 28 Sep 2023 at 5:01am |
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4070 |
Posted: 29 Sep 2023 at 9:35pm |
72 chevy the best one they everbuilt
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35666 |
Posted: 30 Sep 2023 at 9:37am |
Friend of Mine has the FORD Version F250 "CAMPER SPECIAL" to which the Dealer Parts men could NOT EVER locate that series in the parts books, by S/N was a limited run by Ford to test a market and did not fly. Only built IIRC in 73/74 to counter the GM Builds.
His father bought the truck New, he still has the truck today but essentially placed into storage as was getting so hard to get repair parts. Special Springs, axles, brakes by size etc. Bed was 9' and a few inches INTERNAL dimension, the rear axle is far enough back it required a three piece drive line and had the spare inside a Side door on the bedside.
Edited by DMiller - 30 Sep 2023 at 9:39am |
DMiller
Posted: 30 Sep 2023 at 9:42am |
Did a Little digging, Found Both GM and Ford mentioned here. GM started in '68 and continued thru 71/72, Ford added theirs in '73.
Odd buggers
rw
Joined: 28 Oct 2009 Location: United States Points: 388 |
Posted: 30 Sep 2023 at 10:34am |
Needs a gun rack in the back window. Nice truck!
ACinSC
Joined: 16 Dec 2015 Location: South Carolina Points: 3252 |
Posted: 01 Oct 2023 at 10:30am |
Just checked my '69 C 10 and it's 8' 2" long . I knew a 4' by 8' sheet of plywood would fit with the tailgate up . Thanks
Calvin Schmidt
Joined: 11 Sep 2009 Location: Ontario Can. Points: 4583 |
Posted: 01 Oct 2023 at 2:04pm |
I had a 72 3500 with the 8' 6" box. I always bought the camper special for the camper wiring harness. Put a plug on the end for pulling gooseneck trailers. Powered by a 400 big block with a 4 speed, tach and gauges but otherwise a plain work truck. Also had a 71 with the same spec. Later there were at least 4 454 powered trailer pullers .
